Set up for Asus RT-56U router
MrFraggle
Hi can anyone point me in the direction of setup instructions for the above router as everything I do does not seem to work though i suspect that it may well have something to do with in correct login details but I am almost positive they are correct, user name and password though on checking in the member centre I see I have this, @plusdsl.net, after my user name. Should I have included this bit?
But any other settings would be great.
St3
Aspiring Champion
Fixes: 5
Re: Set up for Asus RT-56U router
I have the same router Smiley
All you need to do is add your username@plusdsl.net and your password then save and click on connect. Also once connected to the net check the router for new software because i recently had an update for mine.
MrFraggle
Cheers mate I did not realise I needed the bit at the end of my user name.
St3
Aspiring Champion
Fixes: 5
Yer thats the important bit Smiley Hope you get connected
MrFraggle
Perfect mate. Worked a treat.
Anything else I need to know?
St3
Aspiring Champion
Fixes: 5
Not that i can think of, but if you ever unsure about anything just reply to the post Smiley
