Set up for Asus RT-56U router
FIXED- Subscribe to RSS Feed
- Re: Set up for Asus RT-56U router
10-10-2016 12:59 PM
Hi can anyone point me in the direction of setup instructions for the above router as everything I do does not seem to work though i suspect that it may well have something to do with in correct login details but I am almost positive they are correct, user name and password though on checking in the member centre I see I have this, @plusdsl.net, after my user name. Should I have included this bit?
But any other settings would be great.
Fixed! Go to the fix.
10-10-2016 1:09 PM - edited 10-10-2016 1:11 PM
I have the same router
All you need to do is add your username@plusdsl.net and your password then save and click on connect. Also once connected to the net check the router for new software because i recently had an update for mine.
10-10-2016 1:11 PM
Cheers mate I did not realise I needed the bit at the end of my user name.
10-10-2016 1:14 PM
Yer thats the important bit Hope you get connected
10-10-2016 1:21 PM
Perfect mate. Worked a treat.
Anything else I need to know?
10-10-2016 1:25 PM - edited 10-10-2016 1:26 PM
Not that i can think of, but if you ever unsure about anything just reply to the post
