Service keeps dropping especially in the mornings
- Service keeps dropping especially in the mornings
03-09-2017 1:35 PM
Ive had no luck trying to get to support on the phone so trying here.
My connection drops regularly in the mornings. Today was especially bad with a 15 minute outage at around 12.30pm. Im seriously considering moving away from Plusnet unless this issue can be resolved. Can someone check my line please?
Re: Service keeps dropping especially in the mornings
03-09-2017 1:41 PM
03-09-2017 1:45 PM
Thanks for your username.
My tests aren't detecting any issues. Apart from today, the physical connection seems stable:
Do you experience problems using a wireless or wired connection?
03-09-2017 1:46 PM
Wired. I've disabled wireless on the router as I use a separate wireless access point.
03-09-2017 1:47 PM
I think the next step is to rule out the router itself being the issue. If you connect your PC directly into the Openreach modem, setting up a PPPoE connection that'll narrow down where the problem lies.
03-09-2017 2:14 PM
I've actually plugged in the original Plusnet router now - I was using a BT Hub previously. Lets see how things go and if the connection drops again tomorrow morning I'll post back in this thread.
03-09-2017 2:20 PM
