Service issues in West Yorkshire
- Re: Service issues in West Yorkshire
16-05-2021 11:09 AM
Anyone has internet issues specifically since yesterday regarding slow service, dropping out and disconnects ? Prior to then everything was ok. Looking at the PN service status everything is ok, clearly not for me !
16-05-2021 11:18 AM
@hsbc1972 Probably just you. Sight of your 'Help Desk' page from the Troubleshooting tab on your router, with any personal info redacted, would possibly be helpful.
16-05-2021 11:27 AM
ok thanks, once I worked out how to do that I will give it a go.
16-05-2021 11:43 AM
You can get stats from the hub one if you visit http://192.168.1.254 then click troubleshooting and then help desk.
16-05-2021 11:45 AM
Easy - log into your router (presumably a Hub1), click the 'Troubleshooting' tab -top right, take a screenshot and edit out personal details before uploading to the topic. Picture below might help:
16-05-2021 1:36 PM - edited 16-05-2021 1:36 PM
Welcome to our community forums @hsbc1972 Our service status would be for issues on the Plusnet network that affect a large number of people rather than supplier issues although I appreciate making people aware of major service outages is a good idea, it's something we can certainly take onboard.
Moving on to the issue with your service, there's no major service outages showing that's affecting your line. Looking at your connection pictured below, it's stable and testing your line is showing download speed's OK although your upload's slow but that may be down to the length of your line.
Are you using a wired or wireless connection? Also I've attached the test results below
GEA Test Detail | |||
Circuit ID | NA | Service ID | [redacted] |
Test Outcome | Pass | ||||
Test Outcome Code | GTC_FTTC_SERVICE_0000 | ||||
Description | GEA service test completed and no fault found . | ||||
Main Fault Location | OK | ||||
Sync Status | In Sync | ||||
Downstream Speed | 15.6 Mbps | ||||
Upstream Speed | 0.6 Mbps | ||||
Appointment Required | N | ||||
Fault Report Advised | N | ||||
NTE Power Status | PowerOn | ||||
Voice Line Test Result | Pass | ||||
Radio Frequency Ingress | Not Detected | ||||
Repetitive Electrical Impulse Noise | Not Detected | ||||
Cross Talk | Not Detected | ||||
Estimated Line Length In Metres | 1537.7 | ||||
Upstream Rate Assessment | Reasonable | ||||
Downstream Rate Assessment | Reasonable | ||||
Interference Pattern | Regular Interference Observed Daily | ||||
Service Impact | No Impact Observed | ||||
Interference Duration Longest Occurrence | From21:45to04:00 | ||||
Interference Location | Customer Premise | ||||
Interference Observed In Days | 0 | ||||
Home Wiring Problem | Not Detected | ||||
Downstream Policing Discard Rate | 0.0 | ||||
Customer Traffic Level | Upstream and Downstream traffic detected | ||||
Technology | VDSL | ||||
DP Type | External | ||||
Profile Name | 0.128M-40M Downstream, Interleaving Low - 0.128M-10M Upstream, Error Protection Off | ||||
Time Stamp | 2021-05-03T13:30:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 15.0 Mbps | 15.6 Mbps | 15.2 Mbps |
Up Stream Line Rate | 0.5 Mbps | 0.6 Mbps | 0.6 Mbps |
Up Time | 762.0 Sec | 900.0 Sec | 899.7 Sec |
Retrains | 0.0 | 3.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2021-05-16T13:02:49.753+01:00 | 2021-05-16T13:17:49.753+01:00 |
Ingress Code Violation | 0 | 0 |
Egress Code Violation | 0 | 0 |
Errored Seconds | 1 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
17-05-2021 11:11 AM
many thanks for the info, very impressed. At TT you struggled to get a timely reply let alone that kind of information !
17-05-2021 11:13 AM
im not the most techy person here but hopefully this may help
17-05-2021 11:29 AM
Thanks for that, @hsbc1972 - exactly what I needed, but unfortunately, apart from your horrible attenuation figures(you must be a massive distance from the cab), there is nothing there that shouts out at me, in fact it all looks very reasonable.
I'm afraid all I can suggest at the moment is that you run through the 'speed issues' topic on this board, and then raise a question at faults.plus.net .
You do have an issue, but not one that has an obvious cause.
17-05-2021 5:41 PM - edited 17-05-2021 5:46 PM
@jab1 thanks for the feedback, according to BT records we are about 400m away from our cab. Not sure if they report direct distance or actual distance. We are on a small housing estate thats been here for approx 40 years and not in a remote location !
ps Having reread the info posted yesterday about my line results I see there is mention of distance of 1500+m, presume this is to the exchange rather than the cab ?
17-05-2021 5:44 PM
With the 'reported' attenuation, your cables must go a long way round, then.
17-05-2021 5:49 PM
who knows what they did 40+ years ago.
17-05-2021 5:50 PM
Not me! 😀
