Service Name:Routed PPPoE via Port 4 (modified by user)
- Re: Service Name:Routed PPPoE via Port 4 (modified...
10-10-2014 2:39 PM
Hi
I have a Technicolor 582n. When inside the router -> Advanced settings -> Technicolor Gateway, I have the Service Name with the value "Routed PPPoE via Port 4 (modified by user)" (like in attached pic).
Is this the normal value for this setting? I have been trying to set an open NAT on my PS4, and with the amount of modifications I did, I don't know if this was me, or was already "modified by user" as default.
Message 1 of 3
(3,263 Views)
2 REPLIES 2
Re: Service Name:Routed PPPoE via Port 4 (modified by user)
10-10-2014 3:26 PM
It’s normal. It is where Plusnet turn what is in essence a standard ADSL modem/router into a single router with the input/output to port 4. Mine is just the same.
Message 2 of 3
(1,336 Views)
10-10-2014 3:58 PM
Cheers dude
Message 3 of 3
(1,336 Views)
