Serious traffic management?
- Serious traffic management?
25-10-2015 8:32 PM
I have got my fibre installed after a long wait of 3 years
However I noticed during peak hours (evenings in my case) the download speed is only about 2-3Mbps while in the morning of today (Sunday) it could reach the max speed...
So wondering is that because of the traffic management, or anything else that I am not aware of?
The router is syncked at 39973kbps for over 2 days, so the speed varies should not because of a re-sync.
Thanks in advance!
Regards,
Chong
Thanks in advance!
Regards,
Chong
Message 1 of 3
(687 Views)
2 REPLIES 2
Re: Serious traffic management?
25-10-2015 8:42 PM
Try bouncing your router (Not the modem). Either power off or use the 'disconnect' option if it has one. Leave it disconnected for five minutes, then let it reconnect. IMPORTANT: Bounce the router do NOT do anything to the modem.
There has been an on-going problem with PN's network for nearly a year now. For more information you could look at the lengthy 'Capacity issues' thread.
http://community.plus.net/forum/index.php/topic,140851.0.html
Message 2 of 3
(386 Views)
25-10-2015 9:12 PM
Thanks for the quick reply......
I am using a AIO router ZyXEL SBG3300, shall I do wht you suggested in the post using the AIO router?
Cheers.
Cheers.
Message 3 of 3
(386 Views)
