Serious drop in download speeds
- Re: Serious drop in download speeds
23-08-2015 10:52 PM
Perhaps someone at Plusnet could look into this please
Its been bad all day so after a few hops i am presented with this, and i cant find anywhere to report a possible fault.
Message 1 of 9
(957 Views)
8 REPLIES 8
23-08-2015 11:07 PM
Message 2 of 9
(552 Views)
24-08-2015 7:02 PM
Can you identify the full path of the Gateway you are on with the low speed please as suggested in reply #428 (and reply #424) of the Capacity thread.
Quote from: Anotherone So in summary, it could be useful for users to post not only their TBB graphs and/or BQMs but also the full ID of the Gateway they are connected to, as explained above.
Message 3 of 9
(552 Views)
24-08-2015 9:35 PM
Same here. And this time I don't think it's the 'gateway issue' as multithreading doesn't help.
lo0-central10.pcl-ag08.plus.net
The BTW test gives me the same download speed but then craps out and says it can't get my details 😕
Message 4 of 9
(552 Views)
24-08-2015 10:08 PM
Not looking good. Have you tried a Gateway hop?
I wonder if you possible have a local congestion issue happen?
Message 5 of 9
(552 Views)
24-08-2015 10:46 PM
I couldn't be bothered but I've just checked it again and now it's fine (wonderful in fact):
Quote from: Anotherone Not looking good. Have you tried a Gateway hop?
I checked my modem and router and they were idle at the time.
[me=Andrue]shrugs. [/me]
Message 6 of 9
(552 Views)
24-08-2015 10:51 PM
As you've had few issues of late that might be the best option, it might be a "one-off" for some obscure reason.
Message 7 of 9
(552 Views)
26-08-2015 7:53 AM
@Alucidnation
Re: your reply #1 and my reply #2, I see that in the Gateway thread you identified the gateway as link3-central10.pcl-gw01.plus.net (84.93.249.164) (believed to be pcl-bng02). Are you still connected to that and are your issues continuing?
Message 8 of 9
(552 Views)
26-08-2015 12:58 PM
Message 9 of 9
(553 Views)
