Sent wrong router
- Re: Sent wrong router
Sent wrong router
12-01-2016 1:12 PM
So my 582N died on Saturday morning. Contacted support, no problem, new one in the post.
A near-identical replacement has arrived, but it's missing the red sticker on ethernet port 4, which apparently means it's on the ADSL firmware - no good for me. I've worked in IT for a decade plus so I'm comfortable with flashing a replacement firmware but I have a couple of questions.
I noticed that the new box doesn't have USB, and there isn't a firmware listed here
http://products.plus-payh.co.uk/firmware/
for non-USB FTTC. From what I've read, the only difference is the physical lack of a USB port and that otherwise the router is identical. Is this correct? Is it safe to flash a non-USB ADSL 582N (DANT-T, currently on 10.2.2.B) to an FTTC firmware update from that page?
If it's safe, which of the three should I use?
Message 1 of 3
(690 Views)
2 REPLIES 2
12-01-2016 3:52 PM
From what I understand, you want to use...
10.2.5.2.FO
That version also enables multicast support for Plusnet IPTV services.
I also understand that it won't be a problem if your router doesn't have a USB port.
If you are still unsure, have a search through the forums where there are quite a few posts relating to this.
10.2.5.2.FO
Message 2 of 3
(350 Views)
12-01-2016 5:03 PM
Message 3 of 3
(350 Views)
