Second Plus Net fibre line
BenJSmyth
Hi all,
Just a quick one - do Plusnet offer two lines to residential properties? We have on with fibre on it already and am just investigating a second one.
Ben
Fixes: 12
Re: Second Plus Net fibre line
you can have as many additional lines installed as you want.
you'll pay line rental and broadband fees on it though.
MattyC
Champion
Fixes: 46
You certainly can, though it'll need the sign up of a new account.
pwatson
Don't forget to refer yourself if you do though so that you get a referral discount on the first account Wink
BenJSmyth
That's good news - I may consider it then.
Would there be an install or new line charge for this? I guess I'd have to phone up for a specific deal.
GeordieMark
I enquired about this a while back, and yes it's like getting a new line in so you'd pay an install / activation charge of £50 (IIRC)
Fixes: 167
It'd simply be a second account, so new username, phone number etc.
 Chris Parr
 Plusnet Staff
Fixes: 385
and you can refer yourself Smiley
My Broadband Ping - PN-Fibre
BenJSmyth
Thanks guys. I like the fact you can refer yourself! I'll have to look up the benefits of that.
BenJSmyth
I guess if I did do this then the Plusnet supplied TV - Youview+ - would need to be pushed down the connection its assigned to, rather than load balancing across both connections?
MattyC
Champion
Fixes: 46
That would be the case yes, you will assign a single connection to the box.
BenJSmyth
That's cool - thanks.
Not been on these forums much before but the responses are great, even from Plusnet themselves. Loads better than previous ISP's forums I've used.
GeordieMark
Sorry to hijack the thread, but is there some sort of QoS in place to make sure that someone downloading doesn't cause the TV to buffer?
Fixes: 167
We have traffic prioritisation, so that realtime services shouldn't be impacted by those that aren't as time-sensitive.
 Chris Parr
 Plusnet Staff
GeordieMark
Thought so, cheers Chris
