Sagemcom 2704N Wall Mounting?
- Sagemcom 2704N Wall Mounting?
06-03-2015 5:31 PM
Anyone managed to use the two screw head slots on the back to wall mount it?
To me it looks impossible once you have plugged the leads in.
(Possibly the designer never used one.)
http://www.thinkbroadband.com/speedtest/button/1476198475230638155-mini.png
Message 1 of 3
(744 Views)
2 REPLIES 2
Re: Sagemcom 2704N Wall Mounting?
06-03-2015 5:37 PM
It isn't the best design really, I've tried one but not wall mounted it, the feet kept it stable enough for me.
Message 2 of 3
(506 Views)
06-03-2015 5:40 PM
You can't wall mount unless you use 90deg RJ45 plugs and even then you have to plug them in then mount on the wall
I think that the connection from the modem (or in the case of ADSL the filter) would need to be similar
Basically - despite the holes for wall mounting - you can't
Of course you could use really big standoffs but that rather mucks up the whole idea
Message 3 of 3
(506 Views)
