Sagemcom 2704N Menu question.
dnpark38
Where is the menu giving the connection Statistics Please?
EG. Sync. Speed, Line Attunuation and Noise Margin
http://www.thinkbroadband.com/speedtest/button/1476198475230638155-mini.png
3 REPLIES 3
Fixes: 62
Re: Sagemcom 2704N Menu question.
It isn't available on fibre
dnpark38
Because of this router, or all Plusnet routers?
Thanks.
Fixes: 62
because it isn't a modem which is where it is stored
if you want the line stats other than getting an unlocked modem you would need a vdsl capable router
