Sagemcom 2704N Menu question.
- Re: Sagemcom 2704N Menu question.
13-03-2015 4:06 PM
Where is the menu giving the connection Statistics Please?
EG. Sync. Speed, Line Attunuation and Noise Margin
http://www.thinkbroadband.com/speedtest/button/1476198475230638155-mini.png
Message 1 of 4
(776 Views)
3 REPLIES 3
13-03-2015 4:26 PM
It isn't available on fibre
Message 2 of 4
(507 Views)
13-03-2015 4:39 PM
Because of this router, or all Plusnet routers?
Thanks.
Thanks.
Message 3 of 4
(507 Views)
13-03-2015 4:41 PM
because it isn't a modem which is where it is stored
if you want the line stats other than getting an unlocked modem you would need a vdsl capable router
Message 4 of 4
(507 Views)
