Sagecom 2704n vs 2704n FTTC
- Re: Sagecom 2704n vs 2704n FTTC
23-10-2015 5:16 PM
23-10-2015 5:19 PM
Welcome to the forum btw
23-10-2015 5:22 PM
23-10-2015 5:24 PM
As Oldjim mentioned the ACS is different but I think one of the CRT might be able to get them changed for you at a suitable time.
23-10-2015 5:25 PM
23-10-2015 5:27 PM
23-10-2015 5:31 PM
23-10-2015 5:31 PM
23-10-2015 5:33 PM
Do you have another Router cwade100?
23-10-2015 5:34 PM
23-10-2015 5:36 PM
23-10-2015 5:51 PM
If you want to have access to further parts of the modem/router GUI, log into http://192.168.1.254/expert_user.html in case you hadn't already discovered. If your current ADSL one is the v1 firmware, don't upgrade to v2. You can download an editable text version of the config with the v1 but not the v2, which allows for a moderate amount of customisation.
