Safeguard not working again aaghh!!!
RF_Engineer
Hello (1st post)
So I recently activated Safeguard (in order to block unsuitable sites from a visiting teenager) and it was working initially fine.  However, after a few days it stopped working (and has not worked since). Blocked sites are now readily available for viewing on all connected devices.
Safeguard is still showing as switched 'ON' in my Plusnet account).
I'm using a Hub One and have checked my router dns settings:
Primary DNS: 212.159.6.9,  Secondary DNS: 212.159.6.10
(Can these be changed?  if so, how?)
How can I get Safeguard working again?
Thanks in advance, any advice welcome.  RF_Engineer
31 REPLIES 31
RF_Engineer
Re: Safeguard not working again aaghh!!!
In the absence of any replies I have been in touch with the technical helpdesk -
Matt:
Everything is still blocked on our side. All that can be done is for you to remove the safeguard altogether then re add it when it has gone through
RF_Engineer: I have tried switching it off and back on in my Plusnet account, is that the same as you are suggesting?
Matt: That is right yes
RF_Engineer: Will it then work again?
Matt: After 4 hours, it should do, yes
So I'll try it this evening and see if it works (I have my doubts because I've already tried switching safeguard on and back on a few days ago)  - I can't help wondering if its down to the DNS settings?
RF_Engineer
rongtw
Fixes: 12
TBH safeguard is not all that good , just see these forums .
http://www.techradar.com/news/the-best-free-parental-control-software have a look here Smiley
Moderator's note by Dick (Strat) Link fixed.
30FTTC06
Fixes: 4
rongtw
Fixes: 12
@30FTTC06 thanks Thumbs_Up
RF_Engineer
Well I just checked my account and Safeguard is on but still not working: I can still access illicit sites - aaghh!!!
Looks like I'll have to call them tomorrow, perhaps they have someone a bit more technical who can offer further assistance.
Any techies frequent this board?
RF_Engineer
 Moderator's note by Adie (Dvorak) removed inappropriate image.
30FTTC06
Fixes: 4
I see your frustration, but this is a family site!
RF_Engineer
Plusnet safeguard is ON, I'm supposed to be protected ....
RF_Engineer
30FTTC06
Fixes: 4
Have a look at this site  DNS servers
If you google how to change to these dns servers per device for now(which you can), those servers will give some basic protection until plusnet can look into your problem. best I can advise unless you have a device that has many options like pfsense or a very good router.
  • 208.67.222.123
  • 208.67.220.123
RF_Engineer
Thanks for that
The trouble is that I need the protection at system/router level because it is mostly visiting teenagers with their own tablets, mobile phones etc that I can't access in order to install software or change settings.  Whilst it was working, Safeguard was ideal as sites were restricted at provider level (so there was no easy way for them to bypass it).
Plusnet are supposed to be providing this protection as part of my package, if it doesn't work then they should get it fixed (perhaps by providing a better router) or give me a discount as compensation.
Unless there is any change today I'll be raising a ticket.
RF_Engineer
RichardB
Seasoned Champion
Fixes: 39
Safeguard has never worked for me but I do not use a PN supplied router. Maybe significant maybe not.
I have tried turning safeguard on and manually forcing the BT / safeguard DNS servers, wating several hours etc - no effect.
However, using a static IP (one off £5 fee from PN) I find Opendns and it's free content filter works very well 🙂
My router is set to hand out the Opendns IP address as the DNS.
However, be warned my eldest teenager has found about VPNs..... Most of his school were using them to avoid the schools content filtering!
DNS based content filtering can be bypassed by smart teenagers!
Richard
rongtw
Fixes: 12
Plusnet will most likely say its not their job to watch your children online , Plusnet protect is just a basic filter , if you need better its up you to provide this .
Either with software or a better router .
30FTTC06
Fixes: 4
You will not stop a teenager getting to what content they desire! best you talk to them and have an agreement of what is or isn't acceptable. For young children the filter if fine. As mentioned already twice opendns for sub 10 yr old children will work after that kids will use Tor and or a VPN to flout your attempts to stop them also as mentioned already.
RF_Engineer
If you google how to change to these dns servers per device for now (which you can)...
No I can't as I explained above (no access).
Plusnet protect is just a basic filter , if you need better its up you to provide this.
That may be but even their "basic filter", as you put it, is not working.
If I need a better router than the one supplied then Plusnet should supply it (though as safeguard was working initially for a few days and then stopped this would suggest that the router I have is OK? ).
I haven't altered any settings this end that should make safeguard stop working.
RF_Engineer
rongtw
Fixes: 12
Found this on mr Google.
BT Family Protection
BT FamilyProtection (device level) (announced early 2011)
Windows software supplied by McAfee
"We continue to investigate ISP-level filters. We are clear, however, that no technical solution currently available can provide 100 percent protection for a household. There is no substitute for parental engagement and diligence in monitoring children’s use of the Internet. Our child protection package helps parents to exercise such diligence."[9]
If you read safeguard help pages , it will not work if you don't use PN DNS
