Safe Surf Option - VPN
craigcc
Hi All,
If I enable Plusnets Safe Surf Option will this block VPN access which I need for work?
Any other gotyas with  Safe Surf Option pleas
thanks
Craig
Fixes: 21
Re: Safe Surf Option - VPN
Hi Craig, welcome to the forum btw.
This is the information at the Member Centre -
Safe Surf will block these common ports:
Port
Application
TCP 412 DirectConnect
TCP 1214 Kazaa
TCP 4661 - 4662 eDonkey
UDP 4665 -4666 eDonkey
TCP 5498 - 5501 Hotline
UDP 6257 WinMX
TCP 6699 WinMX
TCP 6346-6347 Gnutella
TCP 6881-6889 BitTorrent
TCP Port 119 Usenet
Plusnet also say -
Please note: We can’t guarantee that Safe Surf will block all Peer-to-Peer and USENET traffic. Some Peer-to-Peer applications can be set to use a different port if the common port is blocked.
I activated Safe Surf on my account years ago and never found any restrictions with my usage. As far as your VPN goes, if it doesn't use any of the ports listed it shouldn't be a problem. The simple answer is to try it and see, you can always turn it off again.
Don't forget, after activating/deactivating Safe Search you need to drop the PPP Internet connection - that's the session to Plusnet not the sync to the Cab (or exchange for ADSL) and then reconnect for it to take effect (similar process for Safeguard). You do this by logging into your 2704n router and clicking the Disconnect button on the home page in the Internet Status box, wait 30 seconds and then click Connect.
craigcc
Brilliant, thanks for your help AnotherOne. Much appreciated. Nice clear answer.
Will take your advice and activate both Safe Surf and see how it goes.
I'll then activate SafeGuard as that seems to block a not of undesirable activity.
thanks
Fixes: 10
Is safe surf actually working these days? I had a feeling it was not.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Fixes: 21
Well you can always test it out, that rumour has been bandied about before with no proof - it's still present in the member centre.
