SOLVED: Internet connection problems: SOLVED
- Re: Internet connection problems
13-03-2016 10:21 AM
Hi, could you please check if there are any ongoing issues in my area please.
Whenever i try and log into my router it comes up with an EE login page unless i connect by wire to the router.
Also speedtest seems to indicate that i am on the EE high speed internet.
My son has been complaining for a couple of days about slow internet and gaming being virtually impossible online at the moment.
I have updated to the latest router firmware "Asus RT-66U" and even reset the router with no luck.
Thanks.
Thanks.
Message 1 of 6
(1,139 Views)
5 REPLIES 5
13-03-2016 10:43 AM
Sounds like you're accidentally connecting to so done else's WiFi!
Message 2 of 6
(599 Views)
13-03-2016 10:46 AM
Thanks for the reply
I have connected by wire and not wirelessly but it still says EE?
EDIT: i also have dual wifi 2,4 and 5, both are connected to my home network and shaowing as EE?
mav:quote
mav:quote
Message 3 of 6
(599 Views)
13-03-2016 11:03 AM
Message 4 of 6
(599 Views)
13-03-2016 11:57 AM
Hi and thank you for all of the replies
i have left everything disconnected for an hour and a half, plugged it all back in again and it all seems to be back to normal now.
I dont know what the issue was but it seems to have resolved itself now
So much for my relaxing sunday morning catching up on the weeks TV
Message 5 of 6
(599 Views)
Re: SOLVED: Internet connection problems: SOLVED
13-03-2016 3:13 PM
HOMEPLUGS probably
Message 6 of 6
(599 Views)
