SNR
SNR
My line went through the SNR reduction from 6 to 3 and speeds went up by several Mbits. Then due to bad weather I got several disconnects and the SNR went back up to 6 and has stuck there for over 2 months.
Will it slowly drop again or do I need to get someone to give BTW a kick?
Re: SNR
I wouldn't hold your breath. I had a repair done to a fault on my line in early January, and the target SNR has remained firmly on 6 dB ever since. It was at 3 dB for ages before that with no issues.
I believe the only way SNR can be reset for FTTC is as part of a fault repair, unless things have changed recently.
Re: SNR
Oh well.......
You would have thought that the system was clever enough to try again after a certain length of time.
maybeicanhelp
Re: SNR
Re: SNR
Ring PN?
Maybe I'll wait until they've fixed the firmware bug I found.....
maybeicanhelp
Re: SNR
Fixes: 20
Re: SNR
@maybeicanhelp wrote:
They can drop you back down at the click of a button.
I think this is not possible on FTTC (unlike ADSL).
maybeicanhelp
Re: SNR
I thought Open Reach had rolled out the upgrade? Maybe I heard some wrong information. I thought it went live September/October time of last year?
Fixes: 20
Re: SNR
That the DLM can change the target SNRM does not mean that an ISP can adjust it at the click of a button.
More recently, the facility for an ISP to request a DLM reset on FTTC is being trialled, but this resets the profile back to the initial state, it does not allow the ISP to choose the parameters such as target SNRM to set it to.
Terranova667
Re: SNR
That is a trial to reset DLM for those that have had their lines banded nothing to do with adjusting the SNR which is still very much in the hands of DLMs auotmated process.
Browni
Aspiring Hero
Fixes: 46
Re: SNR
Upgrade?
You really need to change that user name.
I must have been really bad in a previous life as this was my 3rd ISP in a row that used lithium.
Now you're stuck with me because my new ISP doesn't run a forum Cheesy
maybeicanhelp
Re: SNR
It was from some article I half read a while back, my bad.
Don't worry, wont be posting again. Enjoy yourself.
iangilf
Re: SNR
its about a problem the person has not about someones username why does it matter what they call themselves this place gets worse lol why not help the person in need of help with there line instead of picking things on peoples username .... it dont make sense
