SNR slowly dropping
- Re: SNR slowly dropping
SNR slowly dropping
09-01-2015 8:24 PM
Anyone got any ideas on why for months now my SNR is slowly dropping?
I had a line reset carried out some 6 weeks or so ago and my SNR has once again been slowly dropping. My last re-sync was almost 16 days ago when the up and down SNR was approx. 6.5dB, over that three week period it has now dropped to some 5dB down and 5.7dB up, I'm also seeing erratic spikes and drops in the SNR at irregular intervals which I monitor through DSLStats and my ZyXel SBG3300-N. I know from experience his trend will continue until I get reset to 6dB and the sync rate will drop to lower levels.
Appreciate the SNR fluctuates over a 24 hour period but the overall trend is constantly downwards and has in the past caused my sync rate to keep dropping. The telnet data e.g. attenuation etc. does not change so not that and the quiet line test seems clear.
I should also add that the SBG3300-N is rock solid and holding the connection without too many errors but even that will drop eventually if this continues, any help would be much appreciated.
Message 1 of 6
(1,319 Views)
5 REPLIES 5
09-01-2015 8:29 PM
If it was on ADSL I would have suggested that the bit swapping was losing the higher tones over night and not repopulating them properly
How that relates to fibre I have no idea
Message 2 of 6
(756 Views)
09-01-2015 8:32 PM
Appreciate the response but the tones are recorded when I start DSLStats and there seems to be no difference (or at least little difference) on a daily basis. As you say though not sure if this relates to FTTC anyway.
Message 3 of 6
(756 Views)
10-01-2015 7:19 PM
Crosstalk?
Also I cant see the type of spikes to be able to judge so Im just guessing. BUT.. FeXT is the bane of VDSL. Ive lost circa 30Mb of attainable speed since I got VDSL purely down to crosstalk. Everytime a new user gets added to the cab theres a chance that your SNRm will slowly deteriorate.
I had a bad crosstalk disturber join the cab just before xmas. I instantly lost 1.5dB of SNRm and about 5Mbps of speed. Its quite funny because I can tell each and everytime the other guy turns his router off, or it performs a resync as my SNRm spikes back up to what it used to be. The average loss now through crosstalk amongst users on my forum is running at about 15-20Mb. It just slowly chips away at your SNRm 😕
Message 4 of 6
(756 Views)
10-01-2015 7:21 PM
Quote from: Oldjim If it was on ADSL I would have suggested that the bit swapping was losing the higher tones over night and not repopulating them properly
The theory is exactly the same OJ. Just lots more tones available for use.
Message 5 of 6
(756 Views)
11-01-2015 7:05 PM
Thanks for the response.
The spikes I see only happen once or twice a week so not sure if that is crosstalk as the rest of the time the SNR just slowly changes over the 24 hour period each day, dropping late afternoon by around 0.5dB and then moving around by around 0.1 - 0.2 dB but over weeks the SNR never recovers to the same (or similar) upper level. The trend is maybe a drop (on average) of around 0.2dB per week.
At present my downstream SNR at best is around 5.8 or 5.9dB early morning, this was 6.5dB just 3 weeks ago.
Telnet data at present is as follows, I'm approx. 300m from the cabinet and Openreach tell me the line is pretty straight to my house:
xdslctl info --stats
xdslctl: ADSL driver and PHY status
Status: Showtime
Last Retrain Reason: 0
Last initialization procedure status: 0
Max: Upstream rate = 8598 Kbps, Downstream rate = 55430 Kbps
Bearer: 0, Upstream rate = 8898 Kbps, Downstream rate = 47671 Kbps
Link Power State: L0
Mode: VDSL2 Annex B
VDSL2 Profile: Profile 17a
TPS-TC: PTM Mode(0x0)
Trellis: U:ON /D:ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 5.2 6.0
Attn(dB): 21.7 0.0
Pwr(dBm): 13.0 6.3
VDSL2 framing
Bearer 0
MSGc: 18 29
B: 51 238
M: 1 1
T: 64 13
R: 12 16
S: 0.0347 0.8543
L: 14752 2388
😧 933 1
I: 64 255
N: 64 255
Counters
Bearer 0
OHF: 687969399 549494
OHFErr: 5275 158
RS: 26393394 2655628
RSCorr: 60252736 8031
RSUnCorr: 238564 0
Bearer 0
HEC: 52871 0
OCD: 6 0
LCD: 6 0
Total Cells: 3043845497 0
Data Cells: 1286760820 0
Drop Cells: 0
Bit Errors: 0 0
ES: 1019 144
SES: 1 0
UAS: 26 1025
AS: 1534353
Bearer 0
INP: 3.00 0.00
INPRein: 0.00 0.00
delay: 8 0
PER: 2.22 13.93
OR: 86.10 20.09
AgR: 47757.44 8917.82
Bitswap: 738492/738493 372/379
Total time = 17 days 18 hours 12 min 59 sec
FEC: 60252736 8031
CRC: 5275 158
ES: 1019 144
SES: 1 0
UAS: 26 1025
LOS: 0 0
LOF: 0 0
LOM: 0 0
Latest 15 minutes time = 12 min 59 sec
FEC: 48931 0
CRC: 31 0
ES: 2 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Previous 15 minutes time = 15 min 0 sec
FEC: 28391 0
CRC: 5 0
ES: 1 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Latest 1 day time = 18 hours 12 min 59 sec
FEC: 1087708 5
CRC: 100 3
ES: 20 3
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Previous 1 day time = 24 hours 0 sec
FEC: 1399087 7
CRC: 190 13
ES: 43 13
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Since Link time = 17 days 18 hours 12 min 33 sec
FEC: 60252736 8031
CRC: 5275 158
ES: 1019 144
SES: 1 0
UAS: 0 999
LOS: 0 0
LOF: 0 0
LOM: 0 0
Status: Showtime
Mode: VDSL2 Annex B
Trellis: U:ON /D:ON
Down Up
SNR (dB): 5.2 6.0
Attn(dB): 21.7 0.0
Pwr(dBm): 13.0 6.3
VDSL2 framing
Bearer 0
MSGc: 18 29
B: 51 238
M: 1 1
T: 64 13
R: 12 16
S: 0.0347 0.8543
L: 14752 2388
😧 933 1
I: 64 255
N: 64 255
Counters
Bearer 0
OHFErr: 5275 158
RSUnCorr: 238564 0
Bearer 0
HEC: 52871 0
OCD: 6 0
LCD: 6 0
Drop Cells: 0
Bit Errors: 0 0
ES: 1019 144
SES: 1 0
UAS: 26 1025
AS: 1534353
Bearer 0
INP: 3.00 0.00
INPRein: 0.00 0.00
delay: 8 0
PER: 2.22 13.93
OR: 86.10 20.09
FEC: 60252736 8031
CRC: 5275 158
ES: 1019 144
SES: 1 0
UAS: 26 1025
LOS: 0 0
LOF: 0 0
LOM: 0 0
FEC: 48931 0
CRC: 31 0
ES: 2 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
FEC: 28391 0
CRC: 5 0
ES: 1 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
FEC: 1087708 5
CRC: 100 3
ES: 20 3
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
FEC: 1399087 7
CRC: 190 13
ES: 43 13
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
FEC: 60252736 8031
CRC: 5275 158
ES: 1019 144
SES: 1 0
UAS: 0 999
LOS: 0 0
LOF: 0 0
LOM: 0 0
Message 6 of 6
(756 Views)
