SNR pre-post reset
- Re: SNR pre-post reset
SNR pre-post reset
24-09-2019 10:15 AM
Hi attached is a graph of my snr pre/post either a forced disconnection (pull phone line) or a router reset.
My question is, why does the snr stabilise as the line conditions have not changed (same line/same dslam/same exchange)
Is this variation in snr due to interference?, if so why does it not continue fluctuating?
24-09-2019 11:32 AM
How do you know that this is in any way connected to a disconnection?
It's interesting that the SNR is increasing, not decreasing. The question has to be: what's happening to your sync speed? If that's stable it suggests to me that you are seeing a decrease in background noise during this period.
24-09-2019 11:40 AM
24-09-2019 4:36 PM - edited 24-09-2019 4:44 PM
Hi
I don't know if it is or isn't connected to a disconnection.
Here is a more complete picture.
The modem is a Vigor 2860, and over a longer periods there is a rough pattern, 08:00 - 12:00 and 16:00 - 2300.
DSLAM is a Huawei
24-09-2019 5:42 PM
Hi @dws1900,
I have tested the line form our end of things and the sync speed looks fine, though I can see that there's been some disconnections over the last few days. It's not at the level that we'd consider it a fault and we also don't know what's caused the drops (meaning it may be down to router reboots), but it could be that this is related to the SNR variation. Could you advise if these connection drops are down to router reboots or if they are unknown to you?
24-09-2019 9:37 PM - edited 24-09-2019 9:37 PM
The disconnects were due to my tests, the phenomenon of the snr has occurred prior to the disconnects.
One issue is the line is way too long, and overloaded, this is being investigated outside of the ISP's (PlusNet) domain and cannot be commented here.
Thanks for the line check, if you have a moment an up to date GEA/whatever its called test would be helpful.
25-09-2019 9:58 AM - edited 25-09-2019 9:58 AM
Thanks for getting back to us @dws1900
I've provided a copy of the latest GEA test below
Test Outcome | Pass |
Test Outcome Code | GTC_FTTC_SERVICE_0000 |
Description | GEA service test completed and no fault found . |
Main Fault Location | OK |
Sync Status | In Sync |
Downstream Speed | 21.6 Mbps |
Upstream Speed | 2.0 Mbps |
Appointment Required | N |
Fault Report Advised | N |
NTE Power Status | PowerOn |
Voice Line Test Result | Pass |
Bridge Tap | Not Detected |
Radio Frequency Ingress | Not Detected |
Repetitive Electrical Impulse Noise | Not Detected |
Cross Talk | Detected |
Estimated Line Length In Metres | 1509.1 |
Upstream Rate Assessment | Very Good |
Downstream Rate Assessment | Very Good |
Interference Pattern | Not Detected |
Service Impact | No Impact Observed |
Home Wiring Problem | Not Detected |
Downstream Policing Discard Rate | 0.0 |
Customer Traffic Level | Upstream and Downstream Traffic Detected |
Technology | VDSL |
Current 15Min Bin Retrains | 0 |
Last 15Min Bin Retrains | 0 |
DP Type | External |
Profile Name | 0.128M-40M Downstream 3dB, Retransmission Low - 0.128M-10M Upstream, Error Protection Off |
Time Stamp | 2019-09-12T10:00:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 21.5 Mbps | 21.8 Mbps | 21.6 Mbps |
Up Stream Line Rate | 1.9 Mbps | 2.0 Mbps | 1.9 Mbps |
Up Time | 0.0 Sec | 900.0 Sec | 873.3 Sec |
Retrains | 0.0 | 1.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2019-09-25T08:31:15Z | 2019-09-25T08:46:15Z |
Ingress Code Violation | 2 | 0 |
Egress Code Violation | 18 | 0 |
Errored Seconds | 2 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
If there's anything else we can help with let us know
