SNR pre-post reset
dws1900
SNR pre-post reset
Hi attached is a graph of my snr pre/post either a forced disconnection (pull phone line) or a router reset.
My question is, why does the snr stabilise as the line conditions have not changed (same line/same dslam/same exchange)
Is this variation in snr due to interference?, if so why does it not continue fluctuating?
6 REPLIES 6
Fixes: 419
Re: SNR pre-post reset
How do you know that this is in any way connected to a disconnection?
It's interesting that the SNR is increasing, not decreasing. The question has to be: what's happening to your sync speed? If that's stable it suggests to me that you are seeing a decrease in background noise during this period.
MasterOfReality
Fixes: 57
@Baldrick1 makes a good point here.
Can you let us know @dws1900
Thanks,
MoR
dws1900
@Baldrick1
@MasterOfReality
Hi
I don't know if it is or isn't connected to a disconnection.
Here is a more complete picture.
The modem is a Vigor 2860, and over a longer periods there is a rough pattern, 08:00 - 12:00 and 16:00 - 2300.
DSLAM is a Huawei
TheMightyAJ
Fixes: 126
Hi @dws1900,
I have tested the line form our end of things and the sync speed looks fine, though I can see that there's been some disconnections over the last few days. It's not at the level that we'd consider it a fault and we also don't know what's caused the drops (meaning it may be down to router reboots), but it could be that this is related to the SNR variation. Could you advise if these connection drops are down to router reboots or if they are unknown to you?
 Alex H
dws1900
@TheMightyAJ
The disconnects were due to my tests, the phenomenon of the snr has occurred prior to the disconnects.
One issue is the line is way too long, and overloaded, this is being investigated outside of the ISP's (PlusNet) domain and cannot be commented here.
Thanks for the line check, if you have a moment an up to date GEA/whatever its called test would be helpful.
MatthewWheeler
Fixes: 479
Thanks for getting back to us @dws1900
I've provided a copy of the latest GEA test below
Test Outcome Pass
Main Fault Location OK
Sync Status In Sync
Downstream Speed 21.6 Mbps
Upstream Speed 2.0 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Cross Talk Detected
Estimated Line Length In Metres 1509.1
Upstream Rate Assessment Very Good
Customer Traffic Level Upstream and Downstream Traffic Detected
Technology VDSL
Current 15Min Bin Retrains 0
Last 15Min Bin Retrains 0
DP Type External
Profile Name 0.128M-40M Downstream 3dB, Retransmission Low - 0.128M-10M Upstream, Error Protection Off
Time Stamp 2019-09-12T10:00:00
Parameters MIN MAX AVG
Down Stream Line Rate 21.5 Mbps 21.8 Mbps 21.6 Mbps
Up Stream Line Rate 1.9 Mbps 2.0 Mbps 1.9 Mbps
Up Time 0.0 Sec 900.0 Sec 873.3 Sec
Retrains 0.0 1.0 0.0
Current and Last 15 Minute Bin Performance
Parameters Last Traffic Count(Upto 15 mins) Current Traffic Count(Upto 15 mins)
Start Time Stamp 2019-09-25T08:31:15Z 2019-09-25T08:46:15Z
Ingress Code Violation 2 0
Egress Code Violation 18 0
Errored Seconds 2 0
Severely Errored Seconds 0 0
Unavailable Seconds 0 0
If there's anything else we can help with let us know
 Matthew Wheeler
