SNR act so strange today but there is something else...
FIXED- Subscribe to RSS Feed
- SNR act so strange today but there is something el...
03-08-2018 5:29 PM - edited 03-08-2018 5:45 PM
Hi PN staff
I have notice my fibre SNR downstream went up and down all the time. So, my next action is checking the phone tone.
When I lift the headset off the phone I can hear buzz noise on and off, on and off continue ongoing. Before use to be a steady buzz on the line when lift the phone up. Do PN think it will affect my fibre downstream SNR kept changing every minutes from 5.9dB to 7.6dB and back to 5.9dB and went back to 7.6dB all the times continue could upset DLM? Or, I got nothing to worry about it.
I have upload video for PN staff to watch and listen to phone dial tone here: [URL=http://tinypic.com/r/211s6mg/9]View My Video[/URL]
I have enclosed copy of screenshot between 13:26 and 17:25
Fixed! Go to the fix.
Re: SNR act so strange today but there is something else...
03-08-2018 5:57 PM
Updated:
after 17:30 the SNR now steady at 5.9dB. Very strange.
03-08-2018 6:39 PM
mine did the same with a higher snr rate my max attainable was bigger to now its back to normal god knows what went on
03-08-2018 6:44 PM
03-08-2018 6:45 PM
u sure its not a message been left on the answering machine it also makes that sound
03-08-2018 6:50 PM
03-08-2018 7:51 PM
04-08-2018 2:56 AM
Well well, I wish I never say a word about DLM. As it now happen
DLM has changed my line due to crosstalk for the very first time since 2014.
Since my FTTC was first activated February 2014 with Maximum Attenuation Rate (dB) at 108092k has now dropped to 79400k for the first after DLM has changed my sync rate from 79999k to 78515k. As it appear the cabinet is now in crosstalk BT Bras IP Profile also dropped to 75.92 Mbps from 77.35 Mbps but my throughput speed also drop to 72 Meg from 75 Meg
I think DLM will now working it out for target SNR 3dB to get the line back up to 79999k as possible. (Finger crossed)
Last Remote Defect Indicator/DLM resync: 1st February 2018 at 1:45pm Downstream Upstream Line attenuation (dB): 11.3 0.0 Signal attenuation (dB): Not available on VDSL2 Attenuation rate (kbps): 82489 27617 Connection speed (kbps): 79999 19999 SNR margin (dB): 6.7 15.1 Power (dBm): 12.4 -1.3 Interleave depth: 8 1 INP: 48.00 0 G.INP: Enabled Not Enabled 1st Remote Defect Indicator/DLM resync: 4th August 2018 at 1:15am (after 184 days stable) Downstream Upstream Line attenuation (dB): 11.9 0.0 Signal attenuation (dB): Not available on VDSL2 Attenuation rate (kbps): 79400 27151 Connection speed (kbps): 78515 19999 SNR margin (dB): 6.4 15.0 Power (dBm): 12.4 0.6 Interleave depth: 8 1 INP: 49.00 0 G.INP: Enabled Not Enabled
04-08-2018 8:55 AM
04-08-2018 10:21 AM
Line tests don't show any issues @goldenfibre, I'm not able to see that video for some reason but are you definitely sure that's not meaning you've got a voicemail waiting for you?
04-08-2018 10:32 AM - edited 04-08-2018 10:41 AM
@adamwalker I have request online to get voicemail removed off. The phone tone is now back to normal, no engaged tone. But why is FTTC has dropped again as the Sync Rate drop to 77788 and Line Attainable Rate drop to 79920 but the Line Attenuation has gone up to 11.9dB from 11.3dB (why is more longer distance as the cabinet couldn't move itself?) and BT Bras IP Profile drop to 75.21 Mbps.
5th Remote Defect Indicator/DLM resync: 4th August 2018 at 10:00am (after 8 hours stable) Downstream Upstream Line attenuation (dB): 11.9 0.0 Signal attenuation (dB): Not available on VDSL2 Attenuation rate (kbps): 79920 27465 Connection speed (kbps): 77788 19999 SNR margin (dB): 6.5 15.1 Power (dBm): 12.4 0.9 Interleave depth: 8 1 INP: 49.00 0 G.INP: Enabled Not Enabled
04-08-2018 10:35 AM
@adamwalker You can't see the video because the link is broken try this:
04-08-2018 12:52 PM
@adamwalker could I have a GEA Test please.
05-08-2018 5:17 PM
Hello @goldenfibre,
Thanks for getting in touch. Below is the requested GEA test, please let us know if you need any further assistance.
Test Outcome | Pass |
Test Outcome Code | GTC_FTTC_SERVICE_0000 |
Description | GEA service test completed and no fault found . |
Main Fault Location | OK |
Sync Status | In Sync |
Downstream Speed | 77.7 Mbps |
Upstream Speed | 20.0 Mbps |
Appointment Required | N |
Fault Report Advised | N |
NTE Power Status | PowerOn |
Voice Line Test Result | Pass |
Bridge Tap | Not Detected |
Repetitive Electrical Impulse Noise | Not Detected |
Estimated Line Length In Metres | 243.6 |
Upstream Rate Assessment | Very Good |
Downstream Rate Assessment | Very Good |
Interference Pattern | Not Detected |
Service Impact | No Impact Observed |
Home Wiring Problem | Not Detected |
Downstream Policing Discard Rate | 0.0 |
Customer Traffic Level | Upstream and Downstream Traffic Detected |
Technology | VDSL |
Profile Name | 0.128M-80M Downstream, Retransmission Low - 0.128M-20M Upstream, Error Protection Off |
Time Stamp | 2018-07-23T17:15:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 77.7 Mbps | 79.9 Mbps | 79.7 Mbps |
Up Stream Line Rate | 19.9 Mbps | 19.9 Mbps | 19.9 Mbps |
Up Time | 0.0 Sec | 900.0 Sec | 893.9 Sec |
Retrains | 0.0 | 1.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2018-08-05T15:36:34Z | 2018-08-05T15:51:34Z |
Ingress Code Violation | 1 | 2 |
Egress Code Violation | 0 | 0 |
Errored Seconds | 0 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
06-08-2018 2:31 AM
Thanks but PN Current Line Speed below are wrong not matched BT Bras IP Profile set at 75.21 Mbps
High-speed Broadband |
