SLOW speed tests with speedtest.net? (only)
Fixes: 21
Thought I would check my speed.
Ran up speedtest.net and was getting 15-18Mb DOWN.
BT says 59Mb down
TBB says
So did a gateway hop and got same results.
So is something broken at speedtest.net?
davenos
Re: SLOW speed tests with speedtest.net? (only)
I get the same with speedtest its only once reported me higher than 20mbps despite me syncing at 35mbps all others report me at 33mbps.
It looks like an issue with Speedtest if your getting an actual download speed of 6MB+(49.2mbps) on your connection i would'nt worry.
Fixes: 6
OK here using the top London server.
The bottom London server is reporting my speed a couple of Mbps slower than it should.
Fixes: 21
Tests were run on automatic selection.
Back to normal today. Looks like they fixed it.
