S/N goes up and download speed goes down....again!
FIXED- Subscribe to RSS Feed
- Re: S/N goes up and download speed goes down....ag...
- « Previous
- Next »
Re: S/N goes up and download speed goes down....again!
15-05-2020 2:53 PM
If your line is the same as mine, when the line snr reaches 12db, the download speed will stableize at no lower than 19 Mbs.
15-05-2020 4:06 PM
Generally the falling speed doesn't have a great impact on the number of disconnections which on average is still once a day usually between midnight and 5 am. For a number of months I was getting a consistent 33-35Mbs so having to now make do with around 20Mbs is not acceptable considering how much we pay for line rental.
Ian
11-07-2020 10:02 PM
Persistence does pay off eventually.
Having had endless engineers visits for over a year tinkering with the line with no long term fix I've finally had an excellent engineer do a thorough investigation. He found that he could switch me from my old 60's cabling to a line on a 'new' modern cable which had been added to increase capacity. This has boosted my down sync speed to a stable 40Mbs from 26Mbs and the up sync to 10Mbs from 6Mbs. These could improve further when they get round to re-profiling my line to take advantage of finally having a quality line.
11-07-2020 10:09 PM
@chroma2000 - that's good news. When I got put onto a clean pair from my house speeds went up but then over time crept back down from 44 to 33 and are just stuck there.
11-07-2020 10:34 PM
The router stats look very promising so I'm quite confident that finally having the use of new modern cable will finally provide a solution.
Unfortunately none of the other engineer's considered doing that. They just swapped my line for another line that still used the old sixties aluminium cable.
- « Previous
- Next »
