Router user name and password
lxkid
My internet has suddenly stayed orange when trying to connect to the internet.
My iPad has took me to my Plusnet hub one router , I’m not sure what my username and password is.
Is there anyone one around to help.
Aspiring Hero
Fixes: 67
Re: Router user name and password
It's the same as you use to log into your account. You could also try resetting your router by pushing in the factory reset button using a paper clip or similar. Hold in for around 30 seconds. This should reset your log in details automatically.
lxkid
Do I use the @plusdsl.net or my hotmail.co.uk?
Fixes: 506
Hi there.
You'll use your username in the format of username@plusdsl.net
More info can be found over here.
With that said, I've tested your line and I can see your broadband circuit is affected by a major service outage.
We've been given an estimated completion date of by 9pm tonight.
Apologies for any inconvenience caused.
lxkid
Thank you , you’ve put my mind at ease I’ve been going round the bend trying to get it to come on.
I will leave it now till later.
