Router switching channel and drop in wifi speed
dudders
My router which had previously operated on channel 1 switched to channel 11.  This was accompanied by a drop in speed when tested on the wifi connection speed from 37.x Mbps to around 2.x Mbs.  LAN speed remained a consistent 37 or so Mbps.  Channel 1 not congested, tested using a wifi analyzer app.
Reset the router this morning and now back on channel 1 and wifi speed consistent with the LAN connection speed.
Why did the channel change? Why should the speed drop?  No idea.
May be helpful if anyone else has similar problem.
1 REPLY
Andrue
Re: Router switching channel and drop in wifi speed
Quote from: dudders
Possibly your router detected it has become congested, some routers have the ability to choose the best channel.
Channel 11 might have been better than channel 1 but still worse than channel 1 was originally. Perhaps there was some transient broad spectrum interference. Perhaps your neighbours have been changing channels and caught your router out.
Sadly it's just another case of wifi being a bit ropey. If you want reliability go wired.
