Router suggestions
- Re: Router suggestions
Router suggestions
15-04-2019 3:29 AM
Looking at getting the tp-link vr600 ac1600. Anyone else using this with Plusnet?
15-04-2019 10:03 AM
If you think that the Smarthub is rubbish then you could find that spending lots of money buys you something that’s not much better.
Have you considered running an Ethernet cable or a Poweline network to the other part of your property and installing a Wireless Access Point on the end? This may be helpful regarding Powerline devices https://community.plus.net/t5/Tech-Help-Software-Hardware-etc/Powerline-Unit-Performance/m-p/1607450...
Incidentally have you tried separating the 2.4 and 5 GHz bands on the Smarthub in case that this is the problem? See Section 12 here. https://community.plus.net/t5/My-Router/Using-the-BT-Smarthub-6-on-a-Plusnet-Account/m-p/1587673#M85.... Try each band in turn.
15-04-2019 12:27 PM
BT's latest Hub......whilst not cheap, do they not guarantee a signal in any part of your house ?
15-04-2019 1:06 PM
It’s when I go onto Twitter it’s loading tweets but not showing pictures. When I turn WiFi off and go onto 4G it shows the pictures. All other apps are fine. I’m getting 67mbps so I’m a little confused by it.
15-04-2019 2:13 PM
This is an indication that you need to separate the two bands as I suggested earlier. Just try it, it will take all of a couple of minutes and cost you nothing.
15-04-2019 9:21 PM
Sync speed has also increased to the full 80 mbps now to
DSL uptime: 0 Days, 18 Hours 34 Minutes 54 Seconds
Data rate: 20.00 Mbps / 80.00 Mbps
Maximum data rate: 26670 / 82489
Noise margin: 15.3 dB / 4.3 dB
Line attenuation: 15.6 dB
Signal attenuation:
VPI / VCI: 0/38
Modulation: G_993_2_ANNEX_B
Latency type: Fast Path
Data sent / received: 12190 MB Uploaded / 47067 MB Downloaded
