Router stuck on connecting
Krem
I woke up this morning to find I had no internet and that my router is trying to connect to plusnet, I have found no information on work in the area or faluts. Phone line seems to be working and I have done all the normal router checks.
Could you give your end a check? Smiley
rongtw
Fixes: 12
Re: Router stuck on connecting
Good place to check for faults https://status.zen.co.uk/broadband/outages.aspx
Krem
Thanks for the link, my area is due for work for tomorrow but nothing saying about the area being down - my connection is still down btw Plusnet, would at least like something to say you are looking into it.
Looks like I’ll have to wait and see
Fixes: 31
Or you could contact them and get the fault reported.
Krem
I did yesterday - this silence is annoying and apparently a ‘power failure’ is in the support office now, funny that.
Fixes: 359
If you can PM me your landline telephone number (if you know it) I'll be happy to test your line for you now.
Fixes: 359
Cheers for your PM.
Testing your line is showing your router in sync to the cabinet and isn't identifying a definitive cause of the problem.
Have you tried a factory reset of your router?
If you still can't connect, it may also be worth logging into the router settings at 192.168.1.254 just to make sure you're connecting with yourusername@plusdsl.net and your account password as the password.
Failing that, I'd head on over to http://faults.plus.net as it's likely we'll need to investigate this with our suppliers.
Krem
I filed a Fault yesterday, and the router had already been reset recently. I’ll do another round of checks seeing as you aren’t seeing any issues your end
Krem
Also if this helps the router log has been showing LCP down and timeouts of PADO and PADS packets
Krem
Done a complete factory reset now - still getting the above errors. Nothing else I can do checked everything nothing looks broken or damaged
Krem
The third day now - still getting the PADO/PADS timeouts and the LCP down errors...
We've even gone ahead and tried a second router to no joy.
Fixes: 359
Apologies for the delayed response.
It looks like we've sent you a Plusnet router and your connection came back last Friday evening.
Everything working now?
Krem
Sorry for my late reply also Smiley
Yes, the router came on Friday, however, upon attempting to connect the router would falt out refuse to connect... So utilising the new phone cable that came with the box we turned off the Openreach box to connect it just to check it wasn't that cable - upon switching that back on, everything worked.
So we don't really know if it was the new router or the Openreach box in the end, but we kept the Plusnet router running so that it's easier to find and check faults.
Also, we just had a disconnect for a few minutes, and now the speed seems to have capped at 35mbps - I assume it's just everything trying to resync again?
Fixes: 359
I'm happy to hear you're able to connect.
Testing your line isn't showing your speed to be capped.
Profile Name 0.128M-40M Downstream, Retransmission High - 0.128M-20M Upstream, Retransmission Low
The sync rate is on target too for your estimates.
Sync Status In Sync
Downstream Speed 38.3 Mbps
Upstream Speed 7.6 Mbps
Getting around 35mbps on a speed is about right as it's not very often your throughput would be the same as the actual sync rate. Let us know if you experience any further problems.
