Router staying orange
- Re: Router staying orange
20-06-2017 1:47 PM - edited 20-06-2017 1:47 PM
20-06-2017 1:48 PM
20-06-2017 2:37 PM
20-06-2017 2:44 PM
Does your phone line work?
Have you reported a fault?
20-06-2017 2:45 PM
20-06-2017 2:57 PM
It could be worth going through the steps in the Help Pages testing from the "hidden" test socket in the Master Socket if you have one, and trying another router if you have one.
20-06-2017 3:29 PM
20-06-2017 4:13 PM
Sorry to hear you're having connection problems
From looking at your connection, I can see a couple of drops recently.
Testing your line isn't identifying any Major Service Outages linked to your broadband circuit.
Are you still having problems?
20-06-2017 4:24 PM
20-06-2017 4:31 PM
Is your router still orange?The chart above only shows a couple of outages so something does not add up?
20-06-2017 4:35 PM
20-06-2017 5:49 PM
Then the graph that @Gandalf has shown is not your line - apart from the two short drops it is showing you are connected.
20-06-2017 7:08 PM
Mind dropping me a PM with your username so I can double check?
20-06-2017 8:49 PM
Thanks for your private message @Lee83, it looks like I was on the wrong account. I think your email address registered to your forum account is used by a different account, so I was bringing up that when searching by your email.
This is looking better. I say better, actually worse, but more in line with what you're experiencing.
Testing your line isn't showing any outages associated with your broadband circuit, however the test is failing to complete correctly and I believe you've spoken with one of my colleagues who has raise a fault to our suppliers.
We'll provide an update within 24-72 hours via this ticket
21-06-2017 3:51 PM
