Router setup question - probably rather silly but please advise
- Re: Router setup question - probably rather silly ...
25-06-2015 11:12 AM
Given the time for the Plusnet router to connect automatically via the TR-069 system is there any reason why I can't set the router up in advance - username and password
Having connected - hopefully - is it worth waiting for 48 hours before connecting the Billion 8800NL instead of the modem/router as fitted
Message 1 of 5
(730 Views)
4 REPLIES 4
Re: Router setup question - probably rather silly but please advise
25-06-2015 11:18 AM
No reason to wait that I know of, I've always set them up manually regardless of TR-069 availability.
Why wait to connect your Billion, just check your IP profile (assuming it's available) via BT Wholesale Broadband Performance Test (further diagnostics (as you know)) to get a benchmark before changing over (so you know the Billion is performing as well as the OR modem (or not)).
'Impatience is a virtue.'
Call me 'w23'
Message 2 of 5
(413 Views)
30-06-2015 10:22 AM
Just spotted this reply - thanks
Reason for not setting up the Billion is that I won't order it until fibre is actually working - cynic that I am
Message 3 of 5
(413 Views)
30-06-2015 11:09 AM
Oldjim,
when you get the Billion you might like to check the firmware version,I upgraded mine to firmware version 2.32d.dh14 from the UK support site, it contains a newer version of the Broadcom chipset driver.
It has been solid as a rock for me and works great with DSLStats giving loads of info.
You might see a newer firmware version listed on some sites but don’t upgrade to this version as it has problems and has been withdrawn from the Billion site.
Regards, Pendragon.
Regards, Pendragon.
Message 4 of 5
(413 Views)
30-06-2015 11:14 AM
yes I saw from the thread over at Kitz forum that there were problems with it
Message 5 of 5
(413 Views)
