turn on suggestions
Router - set up automated off on times?
- Router - set up automated off on times?
20-09-2015 11:37 AM
Hi
I'm trying to limit the time that we as a family use the internet and wondered if there is a way to set up the standard plusnet router to switch on and off at preset Times?
Any thoughts or instructions gratefully accepted.
Re: Router - set up automated off on times?
20-09-2015 2:57 PM
Hi, and welcome.
Have you had a look at Access Control in your router this link should take you there http://192.168.1.254/advanced_access.html, you may need to login to this section then acivate the feature to see it properly. I know it is very basic, but It should give you some form of control
21-09-2015 9:09 PM
Thanks I will give it a try.
