Router or line fault?
nigel1971
Can somebody from plusnet staff check my line stats please and show a visual radius? not sure if it's a router fault or a line one, sometimes i can't connect wirelessly, i get the red light on the router at times (other morning for example) and had to reset it, fibre speeds all over the place and ping rates been getting a bit high of late.
Cannot hear a fault on the phone line itself and seems clear.
Fixes: 167
Re: Router or line fault?
Here's the visual radius, I'll run a line test and post the stats shortly:
 Chris Parr
 Plusnet Staff
Fixes: 167
Line test results:
Sync Status In Sync
Downstream Speed 80.0 Mbps
Upstream Speed 20.0 Mbps
Profile Name 0.128M-80M Downstream, Error Protection Off - 0.128M-20M Upstream, Error Protection Off
The test is picking up a potential issue with the copper line, but those stats and the radius logs aren't concerning me really.
 Chris Parr
 Plusnet Staff
nigel1971
Not too bad but seems i can't go a week without a dropout, i'll keep an eye on it but the drops seems to be during early hours.
