Router not arrived
Lou3123
Router not arrived
My router hasn’t arrived and my broadband has just been turned off - thank you Plusnet it’s a great way to start a working relationship!
As I am not going to get one tomorrow and I have to work from home, is there a way I can configure my current router until one arrives?
Please could someone advise ASAP
Thank you
5 REPLIES 5
Fixes: 1,461
Re: Router not arrived
Who have you transferred from and is it Fibre or ADSL?
Lou3123
I am coming across from TalkTalk and yes it is fibre
Thrall
Seasoned Pro
Fixes: 23
Try configuring your current router using the settings found here: https://www.plus.net/help/broadband/broadband-connection-settings/
The router may be locked to TalkTalk though
Fixes: 1,461
Sadly TalkTalk routers are locked down and you won’t be able to use it Sad
Fixes: 1,461
Moderators Note
This topic has been moved from ADSL Broadband to Fibre
