Router modem with ac
- Router modem with ac
Re: Router modem with ac
19-01-2015 2:13 PM
19-01-2015 6:55 PM
19-01-2015 8:28 PM
Quote from: Psalliss Thanks nor. I had read it but then got confused on a different site that is seen.
Think I've narrowed it down to four options.
1 keep existing modem and router - don't really want to as poor router from all I've read
2. Use supplied modem but change router D-Link DIR-850L AC1200.- better router and ac support but still two plugs
3. New ac modem router - Asus DSL-AC68U - from what I've read its a really good modem router and has the ac support I'd like so is future proof but expensive.
4. New modem router - TP-LINK TD-W9980 - one box solution and significantly cheaper than the asus. Doesn't support ac but I have nothing that works off ac anyway and by the time I do ac router modems should be cheaper anyway.
What are people thoughts on the four options above?.
Leaning towards the 4th option as the sensible one but do like the asus but that's the gadget geek in me. Any thoughts? I'm guessing I would notice no difference in wifi speed between ac and n. Also at present in a new build 2 storey semi but hopefully moving in next 6 months to a three storey terrace so not sure of that would make any difference between ac and n
Thanks to all for advice so far
19-01-2015 10:52 PM
20-01-2015 10:32 AM
Prior to the DSL-AC68U we briefly had a Billion 8800axl, which had (in our environment) hopeless wifi performance on 2.4 & 5Ghz bands. We're in a rural location with only a couple of other networks nearby, and couldn't get the device to perform even with Billion's assistance to configure/tune it. We've had various other Billion routers for a good few years now without any issues but it seems there's either a problem with this particular model or we were unlucky with a faulty batch.
After trying a replacement 8800AXL, we ended up sending it back to Broadband Buyer for a refund and replaced it with the Asus.
In terms of DSL sync, we found the Billion to sync faster than a BT HomeHub5 but despite the Broadcom chipset in the Billion the Asus syncs with higher speeds and seems more stable.
20-01-2015 11:02 AM
I used it on TalkTalk for 6 months and on Plus.net for the past 2 weeks. But you can only get it if you're on TalkTalk (or from ebay for £40ish), so if it stops working you're stuffed, but you could buy 3 HG635's to the price of 1 ASUS.
The only problem I have is if I have a server (e.g. a minecraft server) that is accessible externally via myminecraftserver.duckdns.org, internally I have to use the internal IP address e.g. 192.169.1.100, it doesn't matter though.
20-01-2015 11:50 AM
I ended up sending that unit back because the wireless performance was rubbish, so decided to take a punt with the TP Link W9980 after all.
As I have already stated, rock solid (for me) with no DLM issues & syncs no different than the default plusnet kit.
I say go for the cheaper, try it, send it back if you don't like.
As far as no vectoring, well how long will it take BT to roll that out, knowing them another decade
20-01-2015 11:51 AM
20-01-2015 1:32 PM
Quote from: westbusker I remember goldenfibre having issues with the TP Link W9980 & it causing a DLM. In fact it put me off so much I went for an ASUS RT-AC56U AC1200 combined with the openreach modem.
Thanks mate. Very helpful. Do you think I'd notice any difference between ac and n
20-01-2015 1:42 PM
We have a couple of Macbooks that connect with ac and can benefit from faster transfer speeds between either wired devices or other ac clients on our local network.
However... the vast majority of traffic transferred around in our case is between connected computers and the internet... Given that our FTTC delivers around 40Mbs, there's not really any practical difference in terms of download or browsing performance.
Arguably, ac is more "future proofed" as it's the newer standard - so if that's important to you, buy a router with ac support. However, for the majority of typical usage, n will probably be more than sufficient
20-01-2015 1:47 PM
jim:quote
20-01-2015 2:36 PM
It does support a Ewan ports (I think that's one of the ethernet ports reconfigured) so if it doesn't give a very good fibre connection you can always use it connected to the supplied BT modem.
20-01-2015 6:15 PM
20-01-2015 6:59 PM
I use this on my network and leaves me very satisfied. Had no problems with it at all - apart from a few issues which were Plusnet's side.
Looks nice and has full AC wifi and gigabit Ethernet ports as well as the EWAN port.
Also has the inbuilt VDSL so no need for the openreach modem.
NE
20-01-2015 7:08 PM
