Router losing connection
- Re: Router losing connection
13-11-2018 12:49 PM - edited 13-11-2018 12:56 PM
Plusnet supplied router is losing connection fairly frequently. Attached is my log of WAN entries.
I want to add that the speed has always been as advertised - no problems there.
13-11-2018 6:00 PM
Hi there.
Our tests aren't showing a definitive cause for the issue, but we can see there have been drops.
Can you confirm what firmware your router is running on? You can find out by logging in to your router settings at http://192.168.1.254 and scrolling down to the bottom of the page.
We may need to update the firmware if it's on an old one.
13-11-2018 10:31 PM
Plusnet Hub One | Software version 4.7.5.1.83.8.259 | Last updated Unknown
14-11-2018 1:11 PM
Hi @bailtree, thank you, this version shouldn't be causing the drops you are seeing.
Can you have a run through our troubleshooting guides here and connect your router to the test socket as shown here.
If you notice the drops continue after completing these, can you raise it as a fault here and let us know once done so.
