Router keeps resetting.
I have been with Plusnet for about 18 months with no problems at all but in the last couple of weeks my router has started to, fall over, reset, drop out, repeatedly for periods of time every day.
I have run through the troubleshooting but that made no difference.
My connection frezes at the pc, the router is flashing orange and within a minute or two goes through it's reconnection process and eventually turns blue again, very much like someone just hit reset. It happens multiple times every day.
Help?! x
2 REPLIES 2
Re: Router keeps resetting.
This looks fairly similar to the issue I have just posted about.
Have you noticed any pattern, eg. frequency of dissconnection.
Cheers,
Fred
(EDIT: Corrected Link)
Yes I agree, the problem you are having sounds very much like the one I am having. I have not been noting when it happens but will from now on. The only pattern I see right now is 3-4 disconnects within 5-10 mins of each other. I realise that within a 24 hour period that doesn't amount to much of a downtime but It is frustrating and I would like to know why it is happening.
