Router help
- Router help
Router help
17-04-2015 9:53 AM
Hi all. I have just signed up for plus net fiber moving over from BT infinity and would like to know would this router work? http://www.amazon.co.uk/Asus-RT-AC87U-Wireless-Broadband-Router/dp/B00NQY3WO8/ref=cm_cd_ql_qh_dp_t
Message 1 of 2
(413 Views)
1 REPLY 1
Re: Router help
17-04-2015 10:00 AM
Yes, that router (as well as any other with ethernet WAN & PPPoE) will work on Plusnet Fibre (as long as you have a VDSL modem (usually the BT Openreach supplied one)).
If you currently use the HH5 without a separate BT modem then you'd need a different replacement router (with VDSL modem built in) or obtain a BT modem.
The HH5 can be used on Plusnet Fibre if required.
Call me 'w23'
Message 2 of 2
(233 Views)
