Router disconnecting everyday
FIXED- Subscribe to RSS Feed
- Router disconnecting everyday
17-06-2020 12:08 PM
https://community.plus.net/t5/Fibre-Broadband/Router-Disconnecting-at-the-Same-Time-Everyday/td-p/15...
I did call up a few weeks after setup and after running some tests the people I spoke to said they couldn't find anything wrong. I left it but now I'm loosing my patience and its becoming more irritating.
Fixed! Go to the fix.
Re: Router disconnecting everyday
17-06-2020 7:07 PM
18-06-2020 4:55 AM
18-06-2020 9:03 AM
@Gandalf or one of their colleagues maybe able to help.
CJT
18-06-2020 3:06 PM
19-06-2020 10:55 AM
Thanks for getting in touch @Lexi-7
I've carried out some maintenance on our side, the same steps from the linked thread. Could you factory reset your router by pushing a paperclip into the reset pin hole at the back for 20 seconds and let us know if you're still having issues after?
21-06-2020 11:08 AM
10-08-2020 2:56 PM
Hi
I'm currently experiencing very similar issues to what Lexi-7 describes except I'm not being prompted to sign again each time. I'm just losing my broadband connection. It has happened once before a month ago and seemed to sort itself out. However on Friday and today the router is constantly dropping out, orange light, B etc and then struggling to re-connect.
I thought this may be down to my work laptop VPN connection (as it does not seem to happen evenings or weekends) but the router has been dropping out today when the laptop is off and no VPN connection running.
Could someone have a look into this and advise please?
11-08-2020 11:16 AM
Additional: the same thing is happening today. Having experienced no issues yesterday evening, the connection has dropped on 4 occasions so far today (9:39, 9:53, 10:32 & 11:03). It seems like the Hub is just resetting itself and takes 2-3 mins to re-establish the connection on each occasion.
I've restarted the Hub but this has not fixed the issue so i'm at a bit of a loss. Can anyone help please?
24-08-2020 3:23 PM
Just to wrap this up:
Help assistant response 11/8/20: "A potential issue has been detected affecting a number of customers in your area. This has now been flagged to our supplier and as soon as I hear back from them I will update you via text."
Happy to advise that the issue has not occured since. Thanks for the help. 👍
23-09-2020 9:29 AM
Since the commencement of my Plusnet contract, I am also experiencing intermittent loss of broadband connectivity...... flashing orange router light and “B” error. I’ve had the Openreach engineer out , a new wall socket, a new router and underwent numerous test, including router reset etc, etc., yet it still intermittently loses connectivity, and eventually seems to reset itself and I gain broadband connectivity back again. Highly annoying, and I’m awaiting yet another call from Plusnet. I’ve only been with this lot for six weeks and I’m not best pleased !!!
25-09-2020 5:14 PM
Hi there, I am having exactly the same problem. We lose connection around 7pm every evening. We've also had an Open Reach engineer out to check our line and replace the main socket but they couldn't detect a problem, so it sounds like it's your side at Plusnet (based on all the other comments and threads).
Please help @Gandalf , it's driving my family insane!
A
25-09-2020 6:44 PM
Hi.... when you say its "my side", what do you mean ?. I think its a problem with Plusnet on their side, as the Openreach engneer has changed the box in my house, I've been given a new router, and all the tests are showing that there isnt a fault, yet Plusnet has agreed that their examinations have show that I am losing connectivity from time to time..... can't understand whats happening......
27-09-2020 6:53 PM
I meant that to reply to Gandalf not you, sorry.
27-09-2020 7:02 PM
Hey up @alijb If you haven't already done so, I would first advise having a run through our troubleshooting steps here: https://www.plus.net/help/broadband/connection-troubleshooting/ and getting your router connected into the test socket for the time being as shown here: https://community.plus.net/t5/Library/Testing-From-The-Master-Socket/ba-p/1322242
If the issues then persist, please log a fault here with us: https://faults.plus.net and if you let us know once done, we can investigate further.
