Router delivered for upgrade, no change in service
- Router delivered for upgrade, no change in service
22-05-2020 9:12 AM
How long does it take for the speeds to increase? Had the router delivered, but the speeds are exactly the same and I'm not sure if I'm still being charged more for the lower speeds!
An update by a real person would be handy.
Message 1 of 2
(410 Views)
1 REPLY 1
Re: Router delivered for upgrade, no change in service
22-05-2020 2:58 PM
Hey @xhippy01, I've looked into this for you and corrected an issue with the profile on Openreach's side. I've included more info in my email to you.
Message 2 of 2
(373 Views)
