Router connection
- Router connection
Router connection
10-01-2015 3:26 PM
I am having problems with google chromecast since i had Tfibre installed, it wont connect to my wifi network.
I have just tried to log in to the router via 192.168.1.254 but the CP router password on the router doesn't work.
Help!
Help!
Message 1 of 7
(1,059 Views)
6 REPLIES 6
Re: Router connection
10-01-2015 3:31 PM
Are you entering the username as 'admin' and the serial number all in CAPS?
Message 2 of 7
(489 Views)
10-01-2015 3:33 PM
of course!
Message 3 of 7
(489 Views)
10-01-2015 4:57 PM
hi any news
Message 4 of 7
(489 Views)
10-01-2015 8:29 PM
Factory reset ?
Ian
Ian
Message 5 of 7
(489 Views)
11-01-2015 4:11 PM
can anyone help on this, I cant access the router, chromecast wont pick up wifi and i'm stick on next steps, was wondering if the frequency has changed from 2.5 (non fibre ) to 5 (fibre) which could be causing an issue?
Message 6 of 7
(489 Views)
11-01-2015 4:54 PM
You shouldn't need to access your router to get the Chromecast working. I'm assuming you have the app on your phone? Can it 'see' the chromecast? Use the app to set up the Chromecast, choose the correct WiFi network for it to connect to, and enter your routers WiFi password which will be on the card supplied with the router (unless you've changed it). This password will be different to the one used to log in to the router. The plusnet router only has 2.4ghz wifi.
Edit
Also before the Chromecast is assigned to a WiFi network, it will show up on WiFi network lists as if it's a WiFi access point. This may give a clue as to whether or not the Chromecast is functioning properly. If not, reboot or reset it.
Edit
Message 7 of 7
(489 Views)
