Router Setp UP
- Re: Router Setp UP
Router Setp UP
08-09-2021 11:43 PM
Hi, i recently signed up with plus net, i recieved my router and also an sms regarding the phone line being ready, i havent recieved an sms or email about my broadband service being ready, should i connect my router already and see if it works or should i wait for the confirmation ?
Re: Router Setp UP
09-09-2021 7:22 AM
@gucazelli Welcome to the forums. When did you get the notification about the phone being available? I think you should have been given an anticipated go live date for the broadband at some point?
Re: Router Setp UP
09-09-2021 7:52 AM
Re: Router Setp UP
09-09-2021 8:06 AM
@gucazelli In case you have problems contacting PN, try this:-
1. Connect a device onto the router's WiFi or plug a laptop/PC into the router using an ethernet cable
2. Go to the router's homepage at http://192.168.1.254
3. Click on the Advanced Settings tab
4. Type in the admin password found from the back of the router and click the OK button
5. Click on the Continue to Advanced Settings button then the Broadband tab
6. If there's a Disconnect button, click that
7. Change the username to the broadband username in the format of username@plusdsl.net If you can't remember this I'd check for any emails PLUSNETsent you as they'd add the username to the top of the email.
8. Type in the account password, this can be reset here: https://www.plus.net/forgotpassword/ if needed.
9. Hit the Connect button.
Re: Router Setp UP
09-09-2021 8:20 AM
I did that yesterday night just after setting up but it didnt change anything, i’m talking to the plus net team on the phone, they booked an engineer for tomorrow, thanks for your time answering
Re: Router Setp UP
09-09-2021 8:40 AM
OK @gucazelli - worth a try, but you obviously have a problem.
Re: Router Setp UP
10-09-2021 2:03 PM
Sorry to hear about the problems you're having @gucazelli
Looks like an engineer appointment has been arranged. Our faults team will be in touch with further updates once the appointment has gone ahead, and engineer notes have been updated.
