Router Recommendations
Cieran
I'm looking to buy an all in one router (VDSL so I don't need the white box) with external ariels as I have a problem with signal in my house and of course that's fast for around £65-75.
I was looking at this http://www.ebuyer.com/660501-tp-link-td-w9980-n600-wireless-dual-band-gigabit-vdsl2-adsl2-modem-rout... but I'm really not sure so I was wondering what you guys have and could recommend.
Thank you,
Cieran
Fixes: 6
Re: Router Recommendations
Hi Cieran , welcome to the forum Smiley
Quite a few of us around here have the Billion 8800NL , very solid piece of kit
http://www.amazon.co.uk/Billion-8800NL-Gigabit-Wireless-Router/dp/B00K6D2ESM
Kind regards
Mike
Mike
Cieran
Thanks Mike, what's it like with WiFi reception?
dick:quote
davenos
I use a Home Hub 5 and it works great the wireless covers my entire house with very little speed drop(i have quite thick walls).
megabit
I use the Asus DSL-AC68U and have never had a problem with it, I know it's more expensive than the others but I can run my 5K iMac and 2 apple macbook pro's and apple tv all at the same time streaming on wi-fi with no buffering, and the interface for the router is as good as any I have used over the past 15 years or more, and my internal walls are 11 inch thick with floors of over 12 inch thick, hope this helps.
