Router Recommendations
- Re: Router Recommendations
16-09-2015 4:15 PM
I'm looking to buy an all in one router (VDSL so I don't need the white box) with external ariels as I have a problem with signal in my house and of course that's fast for around £65-75.
I was looking at this http://www.ebuyer.com/660501-tp-link-td-w9980-n600-wireless-dual-band-gigabit-vdsl2-adsl2-modem-rout... but I'm really not sure so I was wondering what you guys have and could recommend.
Thank you,
Cieran
Thank you,
Cieran
Message 1 of 5
(1,083 Views)
4 REPLIES 4
16-09-2015 4:24 PM
Hi Cieran , welcome to the forum
Quite a few of us around here have the Billion 8800NL , very solid piece of kit
http://www.amazon.co.uk/Billion-8800NL-Gigabit-Wireless-Router/dp/B00K6D2ESM
Kind regards
Mike
Kind regards
Mike
Message 2 of 5
(721 Views)
17-09-2015 3:07 AM
Thanks Mike, what's it like with WiFi reception?
dick:quote
dick:quote
Message 3 of 5
(721 Views)
17-09-2015 11:09 AM
I use a Home Hub 5 and it works great the wireless covers my entire house with very little speed drop(i have quite thick walls).
Message 4 of 5
(721 Views)
17-09-2015 8:27 PM
I use the Asus DSL-AC68U and have never had a problem with it, I know it's more expensive than the others but I can run my 5K iMac and 2 apple macbook pro's and apple tv all at the same time streaming on wi-fi with no buffering, and the interface for the router is as good as any I have used over the past 15 years or more, and my internal walls are 11 inch thick with floors of over 12 inch thick, hope this helps.
Message 5 of 5
(721 Views)
