Router/Modem Requirements for Fibre?
- Re: Router/Modem Requirements for Fibre?
26-05-2016 9:00 AM
I've just signed up for PlusNet Fibre. I believe that I get a "Hub One" as part of this deal, but I would prefer to use my DrayTek Vigor 2710Vn - at least as the router and DHCP Server. Is this possible?
26-05-2016 9:05 AM
Your router has an in built ADSL modem, with no provision for a WAN connection, so no.
26-05-2016 9:10 AM
So I can't plug the WAN connection from the Hub One into a LAN socket?
If not, can I telnet into the Hub One to set up static bindings for the DHCP Server?
26-05-2016 9:22 AM
No, you would need to do it the other way round, connect the Hub One to the telephone line with the DSLport, and your Router's WAN port to a Hub One LAN port, but your router does not appear to have a WAN port.
