Router Disconnects daily
Re: Router Disconnects daily
Many thanks for checking.
I’ve tried to raise it via your link through the troubleshooting and it looks like it crashed.
Champion
Fixes: 22
From looking at the image, the wireless icon isn't showing a great connection. Try moving closer to the router.
If it still does the same, do you have a laptop/PC to try with?
I’m not going to complicate matters here, but ignore the WiFi signal in the image.
@OskarPapa I’m unable to raise anything right now as I’m getting that error in the image. Makes no odds if I connect to my router, next doors router or do it on the PC. Initially it all started okay and then that error message came up.
Fixes: 107
Hi @caketinwendi,
I'm sorry that it's displaying an error message when you try and access the fault troubleshooter. Despite this, the fault has been raised over to our side successfully and I've added an update to the fault ticket here with the next step towards getting this resolved for you.
 Emily D
@EmilyD I’ve responded to the ticket Thumbs_Up
Fixes: 57
Hi @caketinwendi
I've updated the ticket for you.
Thanks,
MoR
 MoR
@MasterOfReality
Ticket replied to Thumbs_Up
Fixes: 942
Cheers for the heads up, I've added a reply to it.
I’ve responded and I have to say I’m not happy with all this one bit. That discussion I’ve left for debate in the ticket.
Fixes: 942
Thanks, I've added another reply and I've also moved the ticket to my workflow so I'll pick up any replies going forward (Saves you having to keep nudging us over here, though feel free to post here if you still want to)
