Rock solid smarthub gone wobbly last two days
PhyllisTyne
Installed a smarthub a few months ago and its been great with only the usual fortnightly overnight reboots. However, last 2 days have had drops and 5 of these:
16:29:46 03 Nov.ppp:PPP: IPCP_NAK
16:29:46 03 Nov.ppp:PPP: CHAP_SUCCESS
16:29:46 03 Nov.ppp:PPP: CHAP_RESPONSE
16:29:46 03 Nov.ppp:PPP: LCP_GOOD_ACK
16:29:46 03 Nov.ppp:PPP: LCP_REQUEST
16:29:46 03 Nov.:PPPoE error: timeout
I hope its not another problem with this line that has given me a bit of grief over the years. Quiet line sounds fine.
Any ideas? Praying its a BT issue they will resolve but not confident.
PT
14 REPLIES 14
EmilyD
Fixes: 117
Re: Rock solid smarthub gone wobbly last two days
Hi @PhyllisTyne,
I'm sorry that you've been experiencing connection drops over the past few days and for any inconvenience that this is causing you.
I can see the drops from Friday and Saturday on your connection log:
However, testing your line isn't picking up the cause of this issue:
GEA Test Detail
Circuit ID NA Service ID BBEUXXXXXXXX
Test Outcome Pass
Main Fault Location OK
Sync Status In Sync
Downstream Speed 40.0 Mbps
Upstream Speed 10.0 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Estimated Line Length In Metres 639.9
Upstream Rate Assessment Very Good
Interference Pattern Regular Interference Observed Daily
Service Impact Retrains Observed
Interference Duration Longest Occurrence From 16:30 to 16:45
Interference Location Customer Premise
Customer Traffic Level Upstream and Downstream Traffic Detected
Technology VDSL
Profile Name 0.128M-40M Downstream, Retransmission Low - 0.128M-10M Upstream, Error Protection Off
Time Stamp 2018-10-23T12:00:00
Parameters MIN MAX AVG
Down Stream Line Rate 40.0 Mbps 40.0 Mbps 40.0 Mbps
Up Stream Line Rate 9.9 Mbps 9.9 Mbps 9.9 Mbps
Up Time 807.0 Sec 900.0 Sec 899.8 Sec
Retrains 0.0 1.0 0.0
Current and Last 15 Minute Bin Performance
Parameters Last Traffic Count(Upto 15 mins) Current Traffic Count(Upto 15 mins)
Start Time Stamp 2018-11-05T11:21:41Z 2018-11-05T11:36:41Z
Ingress Code Violation 1 0
Egress Code Violation 0 0
Errored Seconds 0 0
Severely Errored Seconds 0 0
Unavailable Seconds 0 0
If your connection drops again, please can you run through our troubleshooting guides here and let us know how you get on.
 Emily D
PhyllisTyne
Thanks for checking Emily. Seems ok now. Hopefully just a blip or BT up to something.
PhyllisTyne
Still getting these drops although not as frequent
Interestingly they are all preceded by a couple of TR69 requests a couple of minutes prior:
15:22:10               13 Nov.               dsl:VDSL Link Down: duration was 568355 seconds
15:21:32               13 Nov.               BR_LAN:The DHCP options that are offered by the device (id:14): DiscoverOptions: 53                61           50           12           60           55 | DiscoverOption55: 1              3              6
15:21:32               13 Nov.               :DHCP Confirmation of Request
15:21:25               13 Nov.               wl0:IGMP join received for group 239.255.3.22 on interface wl0
15:21:24               13 Nov.               wl1:IGMP join received for group 239.255.3.22 on interface wl1
15:21:23               13 Nov.               wl1:A WiFi device <64:5A:04:0D:D9:7B> has successfully connected to SSID (Device/WiFi/SSIDs/SSID[WL_PRIV2G])
15:20:43               13 Nov.               ppp1:TR69 ConnectionRequest Failed
15:20:43               13 Nov.               ppp1:TR69 ConnectionRequest: processing request from ACS
23:18:29               14 Nov.               dsl:VDSL Link Down: duration was 114954 seconds
23:18:13               14 Nov.               wl0:IGMP join received for group 239.255.3.22 on interface wl0
23:18:13               14 Nov.               wl1:IGMP join received for group 239.255.3.22 on interface wl1
23:16:09               14 Nov.               wl0:IGMP join received for group 239.255.3.22 on interface wl0
23:16:08               14 Nov.               wl1:IGMP join received for group 239.255.3.22 on interface wl1
23:16:08               14 Nov.               wl0:IGMP join received for group 239.255.3.22 on interface wl0
23:15:00               14 Nov.               ppp1:TR69 ConnectionRequest Failed
23:15:00               14 Nov.               ppp1:TR69 ConnectionRequest: processing request from ACS
23:01:24
 16 Nov.
dsl:VDSL Link Down: duration was 171751 seconds
23:00:57
 16 Nov.
23:00:56
 16 Nov.
23:00:56
 16 Nov.
22:58:51
 16 Nov.
22:58:51
 16 Nov.
22:58:51
 16 Nov.
22:58:33
 16 Nov.
 Any ideas?
There is some stuff on the Web about google chromecast / home devices causeing problems but it seems they are supposed to be fixed now.
Am getting a lot of these:
Which also points to a Chromecast according to some articles on the Web. Have removed 3X Chromecast and 1XHome mini PSU to see what happens.
PT
Fixes: 1,600
The issues with a Chromecast causing a connection to drop is resolved, though it'd generally would've caused your router continually power-cycle itself as opposed to just drop the connection.
While your connection dropped a few times last week, it appears to be more stable since Saturday night:
How are things looking now?
PhyllisTyne
Hi @Gandalf
Still good since Saturday night but all Chromecast and homehub remain disconnected. Although the Saturday drop was after disconnecting them all so they probably aren't the problem. I'm keeping them disconnected for a while to see what happens and if things stay stable I will introduce them back one by one to see how things go.
As expected all of the wl0:IGMP join received for group 239.255.3.22 on interface wl0 have stopped.
Thanks for keeping and eye on this for me.
Jon
LaurenB
Fixes: 131
Hi @PhyllisTyne, let us know how you get on!
 Lauren Barry
PhyllisTyne
Went down last night but I presume by look of log that this was initiated by BT or the router itself? Esp following entry.
01:51:49
 21 Nov.
:A device reset was performed (GUI/Button)
00:01:39
 01 Jan.
BR_LAN:UPnP functionality has been activated
00:01:39
 01 Jan.
BR_LAN:UPnP functionality has been deactivated (manually)
00:01:37
 01 Jan.
:WAN: SENSING AUTO VDSL
00:01:37
 01 Jan.
ppp1:New DYN ROUTE is added [212.159.6.9/32 gw 195.166.130.251]
00:01:37
 01 Jan.
ppp1:New DYN ROUTE is added [212.159.6.10/32 gw 195.166.130.251]
00:01:37
 01 Jan.
ppp1:PPP: PPP INFO 212.159.6.10
212.159.6.9
00:01:35
 01 Jan.
ppp:PPP: IPCP_NAK
00:01:35
 01 Jan.
00:01:35
 01 Jan.
00:01:35
 01 Jan.
00:01:35
 01 Jan.
00:01:34
 01 Jan.
00:01:34
 01 Jan.
00:01:34
 01 Jan.
00:01:34
 01 Jan.
00:01:29
 01 Jan.
00:01:17
 01 Jan.
wl1:A WiFi device <F0:0F:EC:63:E7:A9> has successfully connected to SSID (Device/WiFi/SSIDs/SSID[WL_PRIV2G])
00:01:17
 01 Jan.
ptm0.101:VLAN VLAN_DATA connected
00:01:16
 01 Jan.
00:01:16
 01 Jan.
00:01:16
 01 Jan.
00:01:16
 01 Jan.
:connection ATM_TV disconnected.[ERROR_USER_DISCONNECT]
00:01:16
 01 Jan.
:connection ATM_DATA disconnected.[ERROR_USER_DISCONNECT]
00:01:16
 01 Jan.
dsl:VDSL link Up: Down Rate=42215Kbps
 Up Rate=12511Kbps
 SNR Margin Down=8.70dB
 SNR Margin Up=6.90dB
00:00:53
 01 Jan.
eth1:[Device Connected] MAC Address:Host Name: Address: 192.168.1.65
 lease duration is 86400 seconds.
00:00:53
 01 Jan.
BR_LAN:The DHCP options that are offered by the device (id:3): DiscoverOptions: 53
61
51
3
6 | RequestOptions: 53
61
54
50
51
00:00:53
 01 Jan.
00:00:44
 01 Jan.
:The NTP server used is:
00:00:44
 01 Jan.
00:00:44
 01 Jan.
:The NTP server used is: ntp.homehub.btopenworld.com
00:00:44
 01 Jan.
00:00:44
 01 Jan.
00:00:44
 01 Jan.
:This Rule has been applied successfully: [id:1
 InternalClient:
 External Ports:(0
0)
 Internal Ports: (0
0)
 Protocol: ]
00:00:44
 01 Jan.
:Updating port mapping rule (1) by UPnP
00:00:43
 01 Jan.
eth1:An Ethernet port is now connected (2/100/FULL)
00:00:42
 01 Jan.
BR_LAN:The LAN DHCPv6 Server is active
00:00:42
 01 Jan.
:The LAN DHCP Server is active
00:00:41
 01 Jan.
BR_LAN: Allocated prefix = fdaa:bbcc:ddee::/64 (valid time = 4293967296 / preferred time = 4293967296)
00:00:41
 01 Jan.
:DNS name resolution is now active
00:00:40
 01 Jan.
wl0:WLAN has been deactivated (BTWifi-X) (band : 5GHz).
00:00:40
 01 Jan.
wl0:WLAN has been deactivated (BTWi-fi) (band : 5GHz).
00:00:40
 01 Jan.
wl1:WLAN has been deactivated (BTWifi-X) (band : 2.4GHz).
00:00:40
 01 Jan.
wl1:WLAN has been deactivated (BTWi-fi) (band : 2.4GHz).
00:00:40
 01 Jan.
wl1:WLAN has been activated (JRSWLAN) (band : 2.4GHz).
00:00:37
 01 Jan.
wl0:(0/36) Channel Hopping initiated/Manually initiated
00:00:37
 01 Jan.
wl1:(0/11) Channel Hopping initiated/Manually initiated
00:00:37
 01 Jan.
:The Modem has successfully powered up
00:00:37
 01 Jan.
:WDG Laststatus:: # Current boot was caused by Soft Reset (SAAF)
00:00:37
 01 Jan.
Mobile resilience ended : RX 0.000000 Mbytes/ TX 0.000000 Mbytes
00:00:29
 01 Jan.
:The Modem underwent a warm reset
00:00:24
 01 Jan.
:WAN: ethernet as WAN
01:51:52
 21 Nov.
:Connection to the Internet has been terminated.(Reboot
Reconfiguration
forced termination)
01:51:52
 21 Nov.
dsl:VDSL Link Down: duration was 281791 seconds
01:51:52
 21 Nov.
:VLAN VLAN_DATA disconnected
01:51:50
 21 Nov.
ppp1:The DYN ROUTE [212.159.6.9/32 gw 195.166.130.251] is deleted
01:51:50
 21 Nov.
ppp1:The DYN ROUTE [212.159.6.10/32 gw 195.166.130.251] is deleted
01:51:49
 21 Nov.
01:48:51
 21 Nov.
:Deleting port mapping rule (5802) by System
01:48:51
 21 Nov.
:Updating port mapping rule (5802) by System
01:48:47
 21 Nov.
:Deleting port mapping rule (5801) by System
01:48:47
 21 Nov.
:Updating port mapping rule (5801) by System
01:48:44
 21 Nov.
:Deleting port mapping rule (5800) by System
01:48:44
 21 Nov.
:Updating port mapping rule (5800) by System
01:30:28
 21 Nov.
ppp1:TR69 connectivity to (pbthdm.bt.mo) has been closed
01:30:27
 21 Nov.
ppp1:TR69 connectivity to (pbthdm.bt.mo) has been initiated
01:30:27
 21 Nov.
ppp1:TR69 receiving InformResponse message
01:30:26
 21 Nov.
ppp1:TR69 event found : 6 CONNECTION REQUEST
01:30:26
 21 Nov.
ppp1:TR69 event found : 4 VALUE CHANGE
01:30:25
 21 Nov.
ppp1:TR69 sending Inform message
01:30:23
 21 Nov.
01:30:23
 21 Nov.
01:30:22
 21 Nov.
01:30:20
 21 Nov.
ppp1:TR69 creating new session with ACS
01:30:17
 21 Nov.
PhyllisTyne
Down again. Chromecasts and Home hub still disconnected so i think we can discount those. Can see any other clues except the TR69's that still precede them.
although the drops aren't that frequent now, they are still irritating after so much stability.
15:22:57
 23 Nov.
15:22:55
 23 Nov.
15:22:55
 23 Nov.
15:22:55
 23 Nov.
ppp1:The NTP server used is: ntp.homehub.btopenworld.com
15:22:55
 23 Nov.
15:22:53
 23 Nov.
15:22:52
 23 Nov.
15:22:51
 23 Nov.
15:22:48
 23 Nov.
15:22:43
 23 Nov.
ppp1:New DYN ROUTE is added [212.159.6.9/32 gw 195.166.130.254]
15:22:43
 23 Nov.
ppp1:New DYN ROUTE is added [212.159.6.10/32 gw 195.166.130.254]
15:22:42
 23 Nov.
212.159.6.9
15:22:40
 23 Nov.
ppp:PPP: IPCP_NAK
15:22:40
 23 Nov.
15:22:40
 23 Nov.
15:22:40
 23 Nov.
15:22:40
 23 Nov.
15:22:40
 23 Nov.
15:22:40
 23 Nov.
15:22:40
 23 Nov.
15:22:40
 23 Nov.
15:22:23
 23 Nov.
15:22:21
 23 Nov.
:HTTP UserBasic login from 192.168.1.76 successfully
15:22:14
 23 Nov.
15:22:08
 23 Nov.
15:22:02
 23 Nov.
15:22:02
 23 Nov.
15:22:02
 23 Nov.
15:22:02
 23 Nov.
dsl:VDSL link Up: Down Rate=40879Kbps
 Up Rate=9999Kbps
 SNR Margin Down=0.00dB
 SNR Margin Up=6.00dB
15:21:34
 23 Nov.
15:21:33
 23 Nov.
Reconfiguration
forced termination)
15:21:32
 23 Nov.
15:21:32
 23 Nov.
15:21:31
 23 Nov.
dsl:VDSL Link Down: duration was 221272 seconds
15:21:20
 23 Nov.
15:21:20
 23 Nov.
15:20:15
 23 Nov.
15:20:15
 23 Nov.
PhyllisTyne
Just as an update, I saw a BT engineer ferreting around in 'my' Smiley cabinet a week or so ago. My connection has now been up for nearly 8 days. Hopefully its not a coincidence and things are fixed.
Fixes: 419
Interesting, I was about to point out that the GEA Test here https://community.plus.net/t5/Fibre-Broadband/Rock-solid-smarthub-gone-wobbly-last-two-days/m-p/1585... indicates that there are regular retrains due to interference at your premises. Hopefully this is a red herring, but worth keeping in mind just in case.
PhyllisTyne
Thanks @Baldrick1. I think I probably am kidding myself that it is fixed as this line has had issues of and on for a few years and all fixes only seem temporary. Hopefully fibre to premises will arrive before I go mad Smiley
RandallFlagg
Fixes: 75
Hi @PhyllisTyne
Thanks for getting in touch - just a quick reassurance that your connection looks fine from this side (in terms of the external connection), but please do get in touch if there's anything else you need.
Best wishes
Dave
PhyllisTyne
Cheers Dave @RandallFlagg
PhyllisTyne
A good run of over 10 days but went down at 12.14 today. Any clues from your end?
