Right choice
- Right choice
Right choice
01-11-2014 12:13 PM
Re: Right choice
01-11-2014 12:17 PM
Re: Right choice
01-11-2014 12:23 PM
Re: Right choice
01-11-2014 12:28 PM
When I have called to ask a question they have answered the phone quickly and have been extremely helpful.....much better than BT.
Can't moan at this for midday on a Saturday:
C:\Users\User>ping bbc.co.uk
Pinging bbc.co.uk [212.58.244.20] with 32 bytes of data:
Reply from 212.58.244.20: bytes=32 time=14ms TTL=55
Reply from 212.58.244.20: bytes=32 time=13ms TTL=55
Ping statistics for 212.58.244.20:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 13ms, Maximum = 14ms, Average = 13ms
C:\Users\User>ping multiplay.co.uk
Pinging multiplay.co.uk [85.236.96.26] with 32 bytes of data:
Reply from 85.236.96.26: bytes=32 time=14ms TTL=59
Reply from 85.236.96.26: bytes=32 time=13ms TTL=59
Ping statistics for 85.236.96.26:
Re: Right choice
01-11-2014 12:40 PM
Re: Right choice
01-11-2014 2:51 PM
Re: Right choice
01-11-2014 2:56 PM
I've not had any major issues in the 20+ months I've been with them -if you consider they have >700,000 customers then you'll appreciate why you'll hear bad stuff about them on the forums as more people tend to come on and complain publicly than come on to praise things when they go smoothly
Re: Right choice
02-11-2014 7:14 PM
Quote from: rowladav I have just ordered plusnet but reading some of the comments here I wonder if it's the right choice
Same here for ordering and go live on 28/11/2013 ;D. I've been having internet since the 90s, I've lost count of ISPs I have had over the years have had a few problems in the past, its pretty easy thus far to establish a OR fault to/ISP fault (ie congestion) or end user fault before contacting support I always find being a polite informed pain in the ass normally get things sorted pretty quickly, Its true what is said about forums, its where people come to moan, look at any ISP forum.
Re: Right choice
03-11-2014 9:03 AM
I've just moved home for the third time since being with Plusnet and it couldn't have gone more smoothly! (apart from my profile being stuck on the old speed...)
You've made the right choice!
Re: Right choice
03-11-2014 5:34 PM
