Reverse lookup.
longedge
Reverse lookup.
I have a static IP. Some years ago I had a change made that meant that a reverse lookup of my IP address returned just the IP address (or similar). At the time, I checked and it was working as intended. I've recently checked and find that it now returns my domain (account) name. Any reason why this has changed?
p.s. - Sorry if this should be in another forum, if that's the case I'm sure it'll get moved Smiley.
Fixes: 78
Re: Reverse lookup.
I honestly can't see why that's been changed but would you like me to get that changed back as it was before?
 Adam Walker
longedge
Re: Reverse lookup.
Yes please. I'm also ambivolent about having a fixed IP. It's not something I've ever made use of, it was just a tick box when I joined last time and came at no cost then. TBH I'm not sure of all the pros & cons.
Fixes: 78
Re: Reverse lookup.
Can I put you on a dynamic IP in that case?
I ask as it's easier, more resourceful for us and I don't have to involve anyone else on this side to get it done.
 Adam Walker
longedge
Re: Reverse lookup.
Yes that will be OK. I can't think of any downside as I've never knowingly made use of it.
Fixes: 78
Re: Reverse lookup.
OK cheers for that.
I've unassigned the IP from your account so if you can power the router off, then back on you should reconnect with a new dynamic IP.
 Adam Walker
longedge
Re: Reverse lookup.
OK rebooted with a new IP. Now all I need is to be able to stay connected for more than a couple of hours at a time Smiley
Fixes: 78
Re: Reverse lookup.
And there's me thinking we'd got you sorted! Wink
Yes, I can see it's dropping out fairly frequently.
I've been looking into it and running diagnostics but we're not seeing any obvious issues.
I'd give the tips here a try next: https://goo.gl/tu2WWu
 Adam Walker
longedge
Re: Reverse lookup.
Yes - since the 19th Jan when I connected the HubOne, my average time connected has been something like 3 hours although I did have one period when it stayed connected for just over 2 days. Before that I had been using my own router (Netgear R6250) with the original BTOR modem and I could go for weeks without losing the connection.
Is it possible to connect the old modem and then connect that to the wan port?
p.s. - I have a nice quiet line and I'm not aware of any problems. I am over half a mile from the cabinet so perhaps that's a factor as well as the fact that my drop wire and I think the cabling to the cabinet is 40+ years old.
Fixes: 78
Re: Reverse lookup.
Yes, you should be able to try connecting with the modem into the router, that would be a good idea just so we can review the connection logs afterwards and see if it looks any different.
 Adam Walker
longedge
Re: Reverse lookup.
I've replaced the BTOR modem and have now connected via that (approx 08:30 24/2/18 ) but I can't monitor my WAN connection now. I'll come back to this in a couple of days and perhaps then my logs at the PlusNet end will show whether there has been any improvement.
longedge
Re: Reverse lookup.
The last entry in the WAN section of my router logs shows a PPoE connection made at 08:33 on 24/2/18 and this was using my original BTOR modem, so over 4 days now without a drop that I can detect.
It seems pretty clear that the integrated modem in the Hub One is not suitable for my line for whatever reason whereas the original one is.
Adam, can I ask you to look at the logs at your end to confirm that my connection hasn't dropped over the last 4 days.
Fixes: 78
Re: Reverse lookup.
Sure, I'd say this looks pretty conclusive:
Link to this file:
 Adam Walker
longedge
Re: Reverse lookup.
Many thanks Adam.
Fixes: 542
Re: Reverse lookup.
No problems. Please let us know if you need any further assistance.
