Returning to Plusnet
- Re: Returning to Plusnet
20-03-2018 12:54 PM
Contract with BT is up and looking to either return to Plusnet on their Fibre 76 deal or go to Sky Fibre Max and have it under one bill with TV.
I've heard Plusnet is heavily throttling speeds at peak times which is slightly off putting. UI of billing and lack of account management apps is slightly off putting as well compared to Sky.
I am currently achieving 75mb DL and 19mb UL with BT, can I expect these speeds to continue when switched over.
Thanks,NE
20-03-2018 12:56 PM
No throttling for me for many years (I get 80/20 pretty much anytime)
Where have you heard plusnet is throttling?
20-03-2018 1:54 PM
If there's any throttling it's generally caused by overloaded BT infrastructure such as 'hot SVLANs'. I assume that this also affects BT subscribers. If you do return then continue to use your Smart Hub to connect, it's got better Wifi performance than Plusnet's offering.
24-03-2018 3:26 PM
Decided to go with Sky's NowTV broadband offering.
Thanks,
NE
