Returning to Plusnet
NorthEasterner
Contract with BT is up and looking to either return to Plusnet on their Fibre 76 deal or go to Sky Fibre Max and have it under one bill with TV.
I've heard Plusnet is heavily throttling speeds at peak times which is slightly off putting.  UI of billing and lack of account management apps is slightly off putting as well compared to Sky.
I am currently achieving 75mb DL and 19mb UL with BT, can I expect these speeds to continue when switched over.
Thanks,NE
Ex Plusnet Fibre customer. Sky Ultrafast (G.Fast) Customer using a Sky Hub 4.2. If you wish to say thanks, please click the thumbs up Thumbs_Up
3 REPLIES 3
tonycollinet
Re: Returning to Plusnet
No throttling for me for many years (I get 80/20 pretty much anytime)
Where have you heard plusnet is throttling?
Fixes: 419
If there's any throttling it's generally caused by overloaded BT infrastructure such as 'hot SVLANs'. I assume that this also affects BT subscribers. If you do return then continue to use your Smart Hub to connect, it's got better Wifi performance than Plusnet's offering.
NorthEasterner
Decided to go with Sky's NowTV broadband offering.
Thanks,
NE
