Return of the dreaded Single Thread Slow Down.
Faizan786
My Broadband Speed Test
I had this issue last year and Gandolff changed my vlan even though it wasn't showing hot, and it resolved issue.
Its been like this for a while.
Single thread test fluctuate, same as last time.
P.S This is on Wired
8 REPLIES 8
MatthewWheeler
Fixes: 480
Re: Return of the dreaded Single Thread Slow Down.
Thanks for getting in touch @Faizan786.
We've tested your line and whilst we can't see any issues remotely we'll speak with our suppliers to see if they can identify any cause.
Apologies for any inconvenience caused
 Matthew Wheeler
Faizan786
Whilst our suppliers QA team still aren't willing to move your circuit to different VLAN, I've been advised that they've raised it internally to check the back-haul network. I'll continue to chase for updates where required and I'll keep you posted.
This is how gandalf resolved my issue last year.
MatthewWheeler
Fixes: 480
Thanks for getting back to us.
We've raised it to the relevant team but similar to last time they're refusing to arrange a move as there plenty of capacity according to them (Apparently there's 5GB spare at the exchange).
I'll update you as soon as I know more
 Matthew Wheeler
Faizan786
Update required please.
Beyhive
Fixes: 44
Hi @Faizan786
I'm sorry to hear you're having connection issues. Checking from this side everything is looking spot on to the router with barely any drops and 45.5Mbps download and 6.9Mbps upload showing to get there with no signs of errors. It is also not testing a hot VLAN. Can I please ask if the above tests were through a wired or wireless connection?
Test Outcome Pass
Main Fault Location OK
Sync Status In Sync
Downstream Speed 45.5 Mbps
Upstream Speed 6.9 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Cross Talk Not Detected
Customer Traffic Level Upstream and Downstream Traffic Detected
Technology VDSL
Current and Last 15 Minute Bin Performance
Parameters Last Traffic Count(Upto 15 mins) Current Traffic Count(Upto 15 mins)
Start Time Stamp 2019-05-23T07:03:29Z 2019-05-23T07:18:29Z
Ingress Code Violation 0 0
Egress Code Violation 0 0
Errored Seconds 0 0
Severely Errored Seconds 0 0
Unavailable Seconds 0 0
Date HOT VLAN(Yes/No) Action Fix Date
23-05-2019 NO
22-05-2019 NO
21-05-2019 NO
20-05-2019 NO
19-05-2019 NO
18-05-2019 NO
17-05-2019 NO
Please run the BT Speedtester service from here using a wired connection.
Once the initial result is completed please click Further Diagnostics.  Please type in your phone number and click run diagnostic test.  This will run a test and send the results to the server for investigation. Once that's done please raise the fault from here and let us know once you've done it so we can progress the fault for you.
 Faris
Faizan786
Faizan786
Went wireless and it worked full blast. Turned back on via lan through Powerline adapter and got full speeds again. Weird must have been powerline adapter limiting speed to 9mb.
Fixes: 1,602
Odd, but it's good to see you back up to speed Thumbs_Up
